Cub Cadet 737-3062 Fluid Hydr/Trans G
   / Cub Cadet 737-3062 Fluid Hydr/Trans G #1
GTSRider
Gold Member
Cub Cadet 3000
Must Cub Cadet 737-3062 Fluid Hydr/Trans G, be used in my Cub Cadet 3206,
or can I use Tractor supply Hydraulic Fluid ?
Also what is the capacity with new filter, on a fluid drain change ?
Thanks,
Pete
Hudson Valley , NY
   / Cub Cadet 737-3062 Fluid Hydr/Trans G #2
Synthetic Drive System Fluid Plus is the recommended fluid for late model Cubs. Many people, myself included, have been using Mobil 1 10W50 synthetic oil instead. I used it for several years in my 3235 with no problems. Mne had an oil leak at the time and $40+ per gallon was getting costly.
Bob B.
Bob B.
Thanks Bob.... will consider a synthetic.... but probably won't go that route... tractor is old , with about 1,200 hrs.
on it...put a lot of new parts on.... CARB to fuel tank is all new. new seals in hydraulic lift lines also.
but anyway.....would you know capacity of fluid in rear tranny ? .....of course , I can always fill slowly ,and check level with dip stick.
   / Cub Cadet 737-3062 Fluid Hydr/Trans G #4
The 3206 manual calls for a capacity of 4.5 quarts.
Bob B.
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
2014 Nissan NV200 Cargo Van (A53422)
2014 Nissan NV200...
2018 John Deere 325G (A47477)
2018 John Deere...
Case International 4210 Tractor (RUNS) (A50775)
Case International...
205028 (A52706)
205028 (A52706)
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
