cub cadet 6284 engine
/ cub cadet 6284 engine #1
scoops
Pittsburgh
Can anyone confirm what engine is in the 6284.
I believe it is a perkins 403d-11
Does anyone have a service manual for it?
I've attached a pdf of that engine at 3400 rpm peaks at 21KW, which is about 28hp.
I have looked around on the internet and found a nice pdf file that gives
a ton of specs on this engines and its other familiy members, its about a 15 mb file.
  • 403d-11.pdf
/ cub cadet 6284 engine #2
I don't have any confirming information for you regarding this. I am not aware that Cub made a manual for this engine available. I do know that you need to be careful of the specs in the tractor owners manual. For example, if you follow the manual recommendation for oil capacity you will end up overfilling the crankcase (according to the dipstick which I trust more than the printed spec).
I would be interested in any information that you find - including the file that you mentioned.
JN
/ cub cadet 6284 engine #3
It's a 1.1 liter caterpillar/perkins. Some of the tags on the motor say CAT, some say Perkins. I think CAT owns perkins? 28 HP is the stated value.
My understanding is these engines are used in many other applications.
Unsure about a service manual, I have seen an engine parts manual online.
JN
JN,
If you have an email address, I can send it to you. Its too large to attach here.
Old Machinist, thanks for that info. Even though the servive manual seems to be for the c11, I bet its close enough.
2018 VANGUARD REM VXP 53FT T/A DRY VAN TRAILER (A59914)
2018 VANGUARD REM...
Deere 333E (A60462)
Deere 333E (A60462)
2004 Gradall XL3100 Highway Speed Wheeled Excavator (A64194)
2004 Gradall...
New/Unused AGROTK YC-32G Horizontal Band Sawmill (A65583)
New/Unused AGROTK...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A62130)
2001...
2022 EZ-GO ELITE...
