cub cadet 2165
   / cub cadet 2165 #1
Mike5375
Mechanicsville Pa.
cub cadet 2165
I have a cub 2165 that after cutting for a while will shut down, will not start back up for a while, Possibly after cooling off. changed fuel filter and oil filter this spring.
   / cub cadet 2165 #2
Try loosening the gas cap to see if it keeps running. The vent in the cap could be plugged causing the tank to build up a vacuum.
Bob B.
   / cub cadet 2165 #3
I had this happen to my 2185. It turns out that my muffler was broken which was heating up the rail where the fuel line is. The muffler was heating up the rail which was heating up the fuel line causing it to "vapor lock". Once the muffler was fixed, it solved my problem.
John Deere 1025R (A53317)
John Deere 1025R...
2018 VOLVO FLAT TOP DAY CAB ROAD TRACTOR (A57192)
2018 VOLVO FLAT...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A57880)
2007 FREIGHTLINER...
8' TRAILER TAILGATE/RAMP (A57192)
8' TRAILER...
2017 JLG Skytrak 6036 6,000lbs 4x4 Rough Terrain Telehandler (A56857)
2017 JLG Skytrak...
UNUSED HYD AUGER (A57192)
UNUSED HYD AUGER...
