cub cadet 2165
   / cub cadet 2165 #1
Mike5375
Mechanicsville Pa.
cub cadet 2165
I have a cub 2165 that after cutting for a while will shut down, will not start back up for a while, Possibly after cooling off. changed fuel filter and oil filter this spring.
   / cub cadet 2165 #2
Try loosening the gas cap to see if it keeps running. The vent in the cap could be plugged causing the tank to build up a vacuum.
Bob B.
   / cub cadet 2165 #3
I had this happen to my 2185. It turns out that my muffler was broken which was heating up the rail where the fuel line is. The muffler was heating up the rail which was heating up the fuel line causing it to "vapor lock". Once the muffler was fixed, it solved my problem.
10' CONTAINER (A57193)
2018 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2018 UTILITY VS2RA...
Willmar 4550 Wrangler Articulating Loader (A56435)
Willmar 4550...
2022 Caterpillar 259D3 (A53317)
2022 Caterpillar...
2012 Ford F-550 Knapheide Service Truck with Liftgate (A56858)
2012 Ford F-550...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55851)
2025 Kivel 48in...
