cub cadet 2165
/ cub cadet 2165 #1
Mike5375
Mechanicsville Pa.
cub cadet 2165
I have a cub 2165 that after cutting for a while will shut down, will not start back up for a while, Possibly after cooling off. changed fuel filter and oil filter this spring.
/ cub cadet 2165 #2
Try loosening the gas cap to see if it keeps running. The vent in the cap could be plugged causing the tank to build up a vacuum.
Bob B.
/ cub cadet 2165 #3
I had this happen to my 2185. It turns out that my muffler was broken which was heating up the rail where the fuel line is. The muffler was heating up the rail which was heating up the fuel line causing it to "vapor lock". Once the muffler was fixed, it solved my problem.
New/Unused 7ft Fork Extension (A61166)
New/Unused 7ft...
Case 580L 4x4 Backhoe (A61166)
Case 580L 4x4...
2017 Skyjack SJ16 500lb. Manlift (A61567)
2017 Skyjack SJ16...
159115 (A60430)
159115 (A60430)
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A61166)
New/Unused...
2024 OMEGA 2700S WHEEL LOADER (A62129)
2024 OMEGA 2700S...
