cub cadet 2165
   / cub cadet 2165 #1
Mike5375
Mechanicsville Pa.
cub cadet 2165
I have a cub 2165 that after cutting for a while will shut down, will not start back up for a while, Possibly after cooling off. changed fuel filter and oil filter this spring.
   / cub cadet 2165 #2
Try loosening the gas cap to see if it keeps running. The vent in the cap could be plugged causing the tank to build up a vacuum.
Bob B.
   / cub cadet 2165 #3
I had this happen to my 2185. It turns out that my muffler was broken which was heating up the rail where the fuel line is. The muffler was heating up the rail which was heating up the fuel line causing it to "vapor lock". Once the muffler was fixed, it solved my problem.
Toro Z Turn (A50322)
Gator XUV560S4 (A50324)
Gator XUV560S4...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
CASE 580M SERIES II TURBO BACKHOE (A51242)
CASE 580M SERIES...
John Deere 331G SKID STEER (A50322)
John Deere 331G...
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
