Cub Cadet 1525 problems
/ Cub Cadet 1525 problems #1
mlewis
cub cadet 1525
I recently purchased a used 2005 Cub Cadet 1525. The tractor is in great shape overall but I am having trouble with the PTO I believe. The blades will disengage after about 20 minutes of mowing. Once they go off, I can re-engage them but then they will disengage every 1-2 minutes. Here is the really strange part. If I sit stationary, the blades will stay engaged. Also, I noticed they will also stay engaged if I only mow at about 1/2 of full throttle or less. If I press the pedal past about 1/2 way the blades disengage again. Also, the blades now stay engaged when I go in reverse, when before the reverse safety switch would disengage them automatically. I ruled out (right or wrong) this being a seat switch problem since it doesn't present itself during the first 20 minutes on the same terrain etc.
I am getting pretty frustrated having to continuously push in/pull out the PTO switch while I mow, or having to mow so slow.
Any help/suggestions on this would be greatly appreciated. Thanks!
/ Cub Cadet 1525 problems #2
How old is the battery? I'd replace it with a new one if it's more than a year old and see if that doesn't fix the problem.
Thanks! I'll give that a try and see what happens.
/ Cub Cadet 1525 problems #4
Since you said the reverse cut out isn't working anymore I'd look at the switch and its wiring. It may have come loose or the wiring may have a rubbed spot shorting out.
CATERPILLAR 304 EXCAVATOR (A65053)
CATERPILLAR 304...
2019 CATERPILLAR 299D3XE SKID STEER (A65053)
2019 CATERPILLAR...
2004 International 4300 ASM Altec AM855 55ft. Bucket Truck (A64194)
2004 International...
2016 GMC Sierra Flatbed Truck, VIN # 1GD42WC83GF101701 (A65563)
2016 GMC Sierra...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
Lowe Pontoon Boat and Trailer (A65579)
Lowe Pontoon Boat...
