Cub Cadet 127
   / Cub Cadet 127 #1
deerman210
kansas
john deere 210
Ive found a cub cadet 127 thats in realy great shape. It comes with a mower deck. The only problem is that it dosent run. It turns over and has good compression but no spark. No grill.
Whats this tractor worth??
   / Cub Cadet 127 #2
Hard to say in this economy. With it not running, I'd guess at least $100, but really not more than $300 unless it has great tires, a good seat and paint that doesn't need to be redone and the spark problem could be cured with new points, plug and condensor. If it has other issues, you can spent a lot of money really quickly that you may not be able to recapture. You might look in the classifieds at IHregistry.com for pricing, too.
I was warned that one of the early hydro models had some problems and to stay away from it. Can't remember if it was this one or not.
   / Cub Cadet 127
A 127 was considered by most to be the best narrow frame tractors. The paint is recent except the painter instead of cub yellow they painted it ih red.
   / Cub Cadet 127 #4
Would you paint it the original factory color or let it go through life in red paint? If you price the paint, it isn't cheap.
   / Cub Cadet 127
i was thinking not redoing it until it needs it again then go cub colors
   / Cub Cadet 127 #6
You don't necessarily have to buy Cub Cadet paint, You could buy paint from say Tractor Supply for about 1/3 the cost, and It's equally as good, if not better. My CC128 Is being painted with the Valspar Cub Cadet Yellow, and Valspar IH White.
2013 Ford Transit Connect Cargo Van (A55852)
2013 Ford Transit...
2007 Ford F-150 Ext. Cab Pickup Truck (A55852)
2007 Ford F-150...
2021 Kubota KX033-4 (A53317)
2021 Kubota...
UNUSED FUTURE BS72 72" HYD BOXBROOM SWEEPER (A57193)
UNUSED FUTURE BS72...
UNUSED LANHERO LDH-SP50 50 TON HYD SHOP PRESS (A57193)
UNUSED LANHERO...
2014 Nissan Rogue Select SUV (A55853)
2014 Nissan Rogue...
