Buying Advice Cub Cadet 1046 - Blade Sharpening Advice
   / Cub Cadet 1046 - Blade Sharpening Advice #1
jpmorgan12
Charlotte, NC
I would like to sharpen the blade on my CC1046. I have 30 hours on it and feel like I'm due.
1. Do I need to remove the deck to sharpen the blades, or can I raise the deck enough to remove them?
2. Can I use a standard wrench and some elbow grease, or should I use an air wrench?
3. Is a bench grinder satisfactory for sharpening, or should I use a file as others have suggested?
4. Any other tips on sharpening the blades?
Thank you!
Jeff Morgan
jeffmorgan@gmail.com
   / Cub Cadet 1046 - Blade Sharpening Advice #2
1. i just raise the deck to remove them. 2. i use a standard wrench or socket to remove. and a torq wrench to put back on. 3. i find a angle grinder dose the job very well.
   / Cub Cadet 1046 - Blade Sharpening Advice #3
Found this on another forum
http://www.rd.com/familyhandyman/ar...arpen/main.html
hope this helps
I take the deck off to sharpen blades at times, other times I jack up mower and take blades off. Use socket & rachet to remove & torque wrench to install. Use bench grinder or angle grinder depending on mood of the day.
   / Cub Cadet 1046 - Blade Sharpening Advice #4
O.K how much torque?:rolleyes:
   / Cub Cadet 1046 - Blade Sharpening Advice #5
I torque the nuts on the blades on my 2544 to 100 ft/lbs. Manual call for 90 to 110 ft/lbs.
Also tighten nuts on other mowers to 100 ft/lbs.
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
Kubota KXO40-4 (A53317)
Kubota KXO40-4...
14C SCRAPER (A58214)
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
NEW Long Forks (A59000)
NEW Long Forks...
2018 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2018 Ford F-550...
