Buying Advice Cub Cadet 1046 - Blade Sharpening Advice
   / Cub Cadet 1046 - Blade Sharpening Advice #1
jpmorgan12
Charlotte, NC
I would like to sharpen the blade on my CC1046. I have 30 hours on it and feel like I'm due.
1. Do I need to remove the deck to sharpen the blades, or can I raise the deck enough to remove them?
2. Can I use a standard wrench and some elbow grease, or should I use an air wrench?
3. Is a bench grinder satisfactory for sharpening, or should I use a file as others have suggested?
4. Any other tips on sharpening the blades?
Thank you!
Jeff Morgan
jeffmorgan@gmail.com
   / Cub Cadet 1046 - Blade Sharpening Advice #2
1. i just raise the deck to remove them. 2. i use a standard wrench or socket to remove. and a torq wrench to put back on. 3. i find a angle grinder dose the job very well.
   / Cub Cadet 1046 - Blade Sharpening Advice #3
Found this on another forum
http://www.rd.com/familyhandyman/ar...arpen/main.html
hope this helps
I take the deck off to sharpen blades at times, other times I jack up mower and take blades off. Use socket & rachet to remove & torque wrench to install. Use bench grinder or angle grinder depending on mood of the day.
   / Cub Cadet 1046 - Blade Sharpening Advice #4
O.K how much torque?:rolleyes:
   / Cub Cadet 1046 - Blade Sharpening Advice #5
I torque the nuts on the blades on my 2544 to 100 ft/lbs. Manual call for 90 to 110 ft/lbs.
Also tighten nuts on other mowers to 100 ft/lbs.
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
flooring (A55758)
flooring (A55758)
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A56435)
2023 New Holland...
