Buying Advice Cub Cadet 1046 - Blade Sharpening Advice
   / Cub Cadet 1046 - Blade Sharpening Advice #1
jpmorgan12
Charlotte, NC
I would like to sharpen the blade on my CC1046. I have 30 hours on it and feel like I'm due.
1. Do I need to remove the deck to sharpen the blades, or can I raise the deck enough to remove them?
2. Can I use a standard wrench and some elbow grease, or should I use an air wrench?
3. Is a bench grinder satisfactory for sharpening, or should I use a file as others have suggested?
4. Any other tips on sharpening the blades?
Thank you!
Jeff Morgan
jeffmorgan@gmail.com
   / Cub Cadet 1046 - Blade Sharpening Advice #2
1. i just raise the deck to remove them. 2. i use a standard wrench or socket to remove. and a torq wrench to put back on. 3. i find a angle grinder dose the job very well.
   / Cub Cadet 1046 - Blade Sharpening Advice #3
Found this on another forum
http://www.rd.com/familyhandyman/ar...arpen/main.html
hope this helps
I take the deck off to sharpen blades at times, other times I jack up mower and take blades off. Use socket & rachet to remove & torque wrench to install. Use bench grinder or angle grinder depending on mood of the day.
   / Cub Cadet 1046 - Blade Sharpening Advice #4
O.K how much torque?:rolleyes:
   / Cub Cadet 1046 - Blade Sharpening Advice #5
I torque the nuts on the blades on my 2544 to 100 ft/lbs. Manual call for 90 to 110 ft/lbs.
Also tighten nuts on other mowers to 100 ft/lbs.
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
2019 Ford F-550 Truck 4x4 Crew Cab Palfinger PSC6025 3 Ton Crane Service Truck (A55973)
2019 Ford F-550...
2015 Ford Taurus AWD Sedan (A54815)
2015 Ford Taurus...
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
2012 CHEVROLET SILVERADO 1500 (A58214)
2012 CHEVROLET...
2018 Freightliner M2 106 AWD Altec AA55 56ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
