CUB 3205
   / CUB 3205 #1
terry beavers
cub cadet 3205
Hi! I'm a new member looking for an answer to a front pto problem. My cub 3205 s vacuum actuator will not disengage. I checked the switch seems to be working. Could it be a bad selinoid not letting the actuator release? Thanks,Terry
   / CUB 3205 #4
Hello & WELCOME to TBN! :)
I moved your thread to the Cub Cadet Lawn & Garden Forum.
   / CUB 3205
I'm going to replace the vacuum selenoid.
   / CUB 3205 #6
Is it serviceable? It might have a piece of debris stuck in it preventing it from operating. I have to service water solenoids all the time at work. Even thought we have to filters in front of the solenoid. Just a thought.
   / CUB 3205 #7
Had this problem early on with my 8 yr old 3204. The electrical operated vac valve was serviceable (at least on the one that came on mine) & I took it appart and cleaned it well. Don't recall if I put any lube on the moving part(s) but it hasn't caused me any problems since then. If I did put any lube on some parts it would have most likely been the silicone spray I have and used for yrs that drys leaving only a film.
   / CUB 3205
When I turn the pto switch off, the vacuum actuator releases some but not enough. When I disconnected the vacuum line it does release fully.When mowing the blades will decrease speed almost to a stop. I noticed it looks as if the actuator is not pulling shut all the way also.
   / CUB 3205
I cleaned the solenoid with no luck. I didn't use any type of lube though. I will reclean and lube this time.
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51242)
2024 AGT...
2019 NEW HOLLAND TS6.130 TRACTOR (A51406)
2019 NEW HOLLAND...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
Wolverine Mini Skid Steer Pallet Forks (A50514)
Wolverine Mini...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2017 Nissan Murano AWD SUV (A50324)
2017 Nissan Murano...
