CUB 3205
   / CUB 3205 #11
I had similar problem. My solenoid was getting plugged with dirt on the vent side port. You could try spraying WD-40 through the solenoid both when engaged and not engaged to try to clear passages. IF that doesn't work. I suggest replacing solenoid. Also, you might want to test the vacuum actuator with a mity vac tool or similar. Disconnect hoses to actuator, connect mity van and pump it down. SHould begin to pull at 3-4" Hg and be fully retracted by 10" Hg. Should stay retracted and hold vacuum without bleeding down.
2022 MDB Green Climber LV600 Plus Mulcher (RIDE AND DRIVE) (REMOTE) (A50775)
2022 MDB Green...
2015 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
JOHN DEERE ZERO TURN LAWN MOWER (A54756)
JOHN DEERE ZERO...
14179 (A55788)
14179 (A55788)
Enclosed Service Truck (A55788)
Enclosed Service...
