CT225 Snow plowing
/ CT225 Snow plowing #1
BobcatTR
Decatur, IL.
Bobcat CT225
Found out the CT225 isnt work a hoot plowing, on frozen rock, and asphalt road.
Tires just slide. I dont have turf tires, mine are the next grade of aggressive.
Is the only solution, chains?
I have a 55 gallon barrel 3/4 filled concrete inside for back weight.
I was hoping it would do better.
Any ideas?
/ CT225 Snow plowing #2
Assume you have R4 (industrial tires),sometimes hard to fit chains on that type;you may want to think about studs.
/ CT225 Snow plowing #3
Any ideas?
I always see chains on them when they are being used for plowing. Not sure were the chains are being sourced. Also make sure 4wd is working. I've seen linkage and propeller shaft issues. :thumbsup:
/ CT225 Snow plowing #4
I do pretty well in snow. Not very impressive on ice. Mine has r4 tires and a box blade on the back.
Thanks guys! Yes, i believe R4 is correct.
We have calcium in tires at work, enloaders, backhoes, etc.
My woodpile is down the hill a bit, and would like to get down to it, to pick up logs etc, to cut and put in my woodboiler.
Woodboiler is down there also.
Always something! Lol!
/ CT225 Snow plowing #9
Forgot to mention check your clearances on the inside of your tires to fenders and framework.
Are your rims adjustable?
Or you may need spacers.
The Euro style patterned chains will ride much nicer on hard and frozen ground as well as providing
much more traction then ladder or duo-grip style chains.
Good Luck
/ CT225 Snow plowing #10
Trygg is what I have on rear. I also have front ones. When chained up my little tractor is almost unstoppable. Search my used name for what I did. Its probably under snow removal. I custom made mins for a perfect fit
Thank you!
Found your post, thank you!
/ CT225 Snow plowing #13
I have heard of some guys having luck with syping (spelling?)the tires. I was thinking about doing it but have not got around to it yet.
/ CT225 Snow plowing #15
I see the same...... R4's as well
Also avoid down pressure on the bucket, if you use excessive down pressure, steering is almost completely negated.
/ CT225 Snow plowing #16
I had some tires siped on my GMC pick up, did not see ANY advantage from before to after........
2017 Hyundai 53' Dry Van Trailer (A62613)
2017 Hyundai 53'...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
Mounting Plate Skid Steer Attachment (A61572)
Mounting Plate...
2360 (A64281)
2360 (A64281)
