CT2025 zerk locations
/ CT2025 zerk locations #1
Redleafmaple
Bobcat CT2025 HST
I was greasing and torquing my ct2025 and I came across greasing the pivot location for the brake pedal (right side under floor). Now the manual doesn't specifically say there is a zerk here, but the picture appears like it has one? Under the tractor is a see through roll pin. Does anyone have a zerk here or the roll pin? Maybe this was a change in manufacturing?
/ CT2025 zerk locations #2
There's a roll pin connecting it to the shaft and the only movement is where the shaft goes in, so pretty sure there's no greasing required. Sometimes the manual calls out things for various models and years and yours might not have it.
Yea I can see them doing that. It'd be nice if they wrote which models it applies to if that's the case. I guess I'm more interested to see what other 2025 owners have over there too
/ CT2025 zerk locations #4
Do you have a Right and Left brake pedal? From your pic, it looks like you only have the one, same as mine. I believe the non-HST versions have the 2 and thus the Right brake pivot and the need to grease it.
I have a hydro and yes only the one brake that controls both rear wheels. The manual trans has the split brake.
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2013 Infiniti JX35 AWD SUV (A61574)
2013 Infiniti JX35...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2022 EZ-GO ELITE...
2021 New Holland 1428 Rake (A63688)
2021 New Holland...
