MoPops
- Joined
- Mar 9, 2014
- Messages
- 1,285
- Location
- Center, Mo (small town, it exists)
- Tractor
- Bobcat CT225, John Deere X540
Found a relatively inexpensive 6 1/2’ disc harrow at RuralKing. Made by King Cutter. Doesn’t seem very heavy duty, but I’m just going to use it for a couple of acres of food plots, and maintaining 9 acres of CRP. I don’t have AG tires on my CT225, but have the utility tires. Think my Bobcat (with filled tires (beat juice) can handle 6.6’? The disc is normally $1599, I found one for $1,150. It’s 650 pounds. I’m not 100% sure my 3 pt hitch will lift it. I know I can make adjustments to the discs to make them less aggressive, and pull easier. Hoping I can just use it. The CRP is in beans now, going to CRP this spring. (No till beans). The food plots have been tilled the last few years.
Thx
Jeff
King Kutter 6 1/2' Angle Frame Disc Harrow, Red - 16-20-G-SB-C-RR
KING KUTTER'S ANGLE FRAME DISC HARROWS are constructed with heavy rigid angle iron. It connects easily to any three-point hitch with category one specifications. The disc gang axles are made of 1" square steel rods mounted on double thrust ring gray-iron
www.ruralking.com
Jeff
