CS2220 Kerrr..klunk; beware
/ CS2220 Kerrr..klunk; beware #1
Coyote_CS2220
BC
2023 Kioti CS2220, Yale GLP050TG, Husqavarna Z242F, Yamaha XT250, 2017 Desert Point Kennels GSP from Yuma AZ
At 161 hours on this 2023 unit and today while moving a load of marble I felt a small Kerrr...klunk when going over a small bump and when shifting from forward to reverse on the HST.
At first I thought it was the new ballast on my 3pt hitch shifting left-right, but a hand on the ballast soon confirmed that was not it.
When I was finished work I parked it, pulled out the floor jack and checked the FEL frame bolts, axle bolts and frame bolts.
Sure enough some were loose:
1) the two 17mm bolts holding the front axle to the frame right in front of the oil pan.
2) left hand side FEL frame bolts.
3) right hand side frame bolts behind the rear tire.
I pull both rear tires and check all of the rear frame bolts and the LH side was good. Same with the RH FEL frame bolts.
???Must have been different people or impact guns putting things together.
A little locktite and a torque wrench quieted things down.
Just a heads up if you sense a Kerr...Klunk on a bump or when shifting from forward to reverse with a load on the FEL.
/ CS2220 Kerrr..klunk; beware #2
I make a point to check the FEL mounting bolts and my wheel torque at least 1-2 times a month if it's getting heavy use.
I'll have to check the axle bolts on mine, not sure I ever have.
/ CS2220 Kerrr..klunk; beware #3
On my unit, i tighten everything a few months after buying tractor. They have never loosened up again….i check regularly all the time.
except for those pesky bolts that hold the pivot pin/grease zerk fittings on loader. Those bolts always loosen up. But there not strategically significant for safe loader work. Even if missing, pin cant fall out due to snap ring securing pin.
10000LBS Two Post Automotive lift (A64194)
10000LBS Two Post...
2023 JOHN DEERE 310P BACKHOE (A65053)
2023 JOHN DEERE...
More info coming soon (A61574)
More info coming...
2021 Caterpillar 259D3 Compact Track Loader Skid Steer (A64553)
2021 Caterpillar...
2014 KUBOTA R520ST WHEEL LOADER (A65053)
2014 KUBOTA R520ST...
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A64553)
2014 Caterpillar...
