Cruise control
/ Cruise control #1
mercuryman
Ontario Canada
Kioti CK25 HST
First time out on tractor 04 kioti CK25 HST and cruise control not working is there a way to get it to work
/ Cruise control
The cruise control seams to be mechanical the linkages are not moving when lifting on cruise leaver should I lube where it go's into transmission
/ Cruise control #5
I have a 2004 CK30hst and the cruise isn't electrical or magnetic. It's mechanical and just locks the pedal in the position where your foot has it. I haven't looked at mine for some time. Don't use it much. I'll check it and let you know what I find out.
/ Cruise control
Hi thanks to everyone I got the cruise control working
/ Cruise control #7
mercuryman - That was a LAME answer " I got the CC working . Would have been a lot better to let us all know what you did to fix it to help the next guy with the same problem !
/ Cruise control
YES my cruise is working I lubed the linkage and flipped the switch and it worked what more do you want
/ Cruise control #9
It’s all about helping one another. We share information to learn!
That’s how this site works.
/ Cruise control #10
Could not get my cruise to work on new 2016 NX, and it turned out to be the brake lever to lock pedals together was not engaged!! Sometimes the answer is simple. 😜😜
40' Used Container, High Cube, Single End Doors (A62679)
40' Used...
2022 EZ-GO ELITE...
2020 KENWORTH T60 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 KENWORTH T60...
Goosen Bale Chopper Hay Blower (A65579)
Goosen Bale...
Striker Slide in Spreader Box (A62679)
Striker Slide in...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
