Sodo
Elite Member
- Joined
- Apr 21, 2012
- Messages
- 3,304
- Location
- Cascade Mtns of WA state
- Tractor
- Kubota B-series & Mini Excavator
Sodo,
When looking at this manifold could you check a few items.
1) Is plug "D" directly inline with the pressure or pump supply port. If i would suspect there would be a check valve behind this.
Hi oldnslo
I finally had time to open up this manifold again. Yes there is a spring and check valve behind the "D" plug. It is inside, as in my (red) drawing. The 3 places in the manifold, that it could leakdown are here: A, B, C. How I can figure out which one is leaking?
I decided to first inspect the B) Hold valve. It's a spring-loaded check valve. The spring is very light.
Looking at the seat, the contact ring where the ball would seal against the Aluminum manifold has a small lump in the worst place. The black is not corrosion. The black looks like there was galling, which rolled up a small 'burr' at the yellow arrow. This would definitely make it leakdown, but I can't imagine what could lift up a burr (other than a mfg error, at which the Walkie would have leaked down from day1).
I can see the burr with a magnifying glass, and I can feel it with a screwdriver probe, it can't possibly seal tight.
But what to do about it? Can I lightly "peen" the Aluminum seat with the checkvalve's ball, and smash the burr down? By driving the the ball with a light hammer blow. What do you think?
The ball does not appear to be inconsistent in any way, do they wear out? --i.e. should I replace the ball? it's 0.34" dia. The spring appears to be OK.
I don't see anything wrong with valves A) & C) by the naked eye nothing looks out of order. But this ball-seat sure looks like the leak.
