Crown 20MT Walkie forklift (lift-lower valve problem)
   / Crown 20MT Walkie forklift (lift-lower valve problem) #11
Sodo,
I used to design manifolds like this so bear with me on this.
"F" looks like a solenoid operated valve but not 100% sure. Are there any numbers or letters on the tag? This would be for electrically lowering the mast Vs manual. This could be a leak path and should unscrew.
Black device looks like a manual lowering valve. It could be a cartridge assembly or spring loaded. Unscrew it carefully in case it is under spring load so that parts don't fly out. Since this is what you have been operating to lower I would check this out first
Are any of the plugs labeled B - E directly across from the pressure port? If yes remove that plug carefully and see if there is a spring and ball under it. There could also be a threaded insert style check. I doubt the check is your problem but finding it would at least identify another potential leak point.
I would suspect that the rest of the plugs B - E are being used to block the drill paths required to machine the circuit in this manifold.
Good luck
I won't be checking this site until late tomorrow evening or Saturday some time.
   / Crown 20MT Walkie forklift (lift-lower valve problem) #12
i'd say oldnslo is correct, and if i inderstood your diagram correctly when you operated the electric switch that was connected to the linkage one way the pump ran and the other it lowered? if thats the case the solenoid (F) is probably what lowers the forks the manual linkage is just a backup in case the solenoid fails or power is off.
   / Crown 20MT Walkie forklift (lift-lower valve problem) #13
Check the solenoid valve on the parker block and the switch the wires are connected to. The solenoid is a lock valve, its either stuck/broken or the switch is energizing it. The mechanical valve provides the rate of down, the solenoid should be the "lock". Its been a few yrs since I worked for Crown and my memory is "fuzzy" as our territory didnt have a pile of these to work on. Ill check back on the thread to see how you make out.
Went to OMNI SEALS & PACKING for new o-rings. Sorry I intended to list the sizes (for forum completeness) but did not write them down. However they did say the sizes were standard.
I replaced the 4 O-rings and put it all back together, it still leaks down! :thumbdown:
There was some corrosion in the solenoid o-ring land but I cleaned it up.
OldnSlow I didn't see your post before reassembling! :mad: Thus I did not look behind any of the plugs, I thought they were just "plugs" but now it does make sense to me that there could be a checkvalve across from the pressure "in" port. It's "D", the biggest SAE plug and is across from the pressure "in" fitting.
The manual lower valve seat looks perfect, and the spring is pushing it pretty hard into its seat. It seems that when the manual valve seats, that is the 'lock'.
JS5020 Thanks very much for joining in, I still don't understand what the solenoid does. It gets 12v during the "up" (while the pump is running). I gave it 12v, it clicks lightly, and I can see a little movement. Could it be related to the 2nd stage of the mast? As there is a button switch that is pressed when the 2nd stage mast is at the bottom.
Here's whats inside the valve body again. (pics repeated from previous page)
I'm pretty bummed I did not open that bigger SAE plug to look for a checkvalve. JS5020, do you think I should go back in and look for a checkvalve behind that larger plug (D)?
   / Crown 20MT Walkie forklift (lift-lower valve problem) #15
The "black" part of the valve should control rate of travel (either up or down) and the "silver" solenoid either opens or closes the fluid path to the tank, it is what they call a "lowering valve". Remove 12v from it while lifting and if it is good it will hold the fluid from going back to tank and the mast should remain up. A similar setup is found on their pallet jacks except there is no provision to control the rate of drop, one just hits down button and that solenoid is energized and the forks go down, when they malfunction the jack will lift slow but immediately lowers once the raise button is released.
   / Crown 20MT Walkie forklift (lift-lower valve problem) #16
If you rotate that solenoid to show the bottom of the plunger it should be able to be dissambled and the plunger might be broke or bent causing it not to seal and allowing fluid to go right on by to tank,,, I dont think you can buy the individual parts short the coil or the complete stem but you can see of the plunger is what ails it.
Black valve controls the lowering. It has the 45d 'seat' for shutoff. A fairly hefty spring holds this valve against its seat and I couldn't see anything wrong with it (with a nakd eye). Depending on the valves position, the tapered diameter controls the down speed against gravity.
Still having a hard time understanding the 12v valve, but thanks for trying! One of the leads comes from the motor solenoid terminal, so its given 12v during an "up" command (whenever the motor gets 12v). I suppose it loses 12v when the motor loses 12v. I'm going to have another look at it with your comments in mind.
I think I have to take it all apart again to look for a check valve. And I will have another look at the solenoid valve while in there, adreed if it's hot holding tight then it will bleed to rtn.
Do you think there is a check valve that takes the hold pressure off the pump? Or should I look for a check valve in the pump?
   / Crown 20MT Walkie forklift (lift-lower valve problem) #18
The silver solenoid allows the lower function, if its "on" through any means when lifting or when the control is in neutral the mast is going to come down.
Try this put everything back together and then unhook the wires to the silver solenoid, plug the truck in and select raise, unit should raise and hold position as long as the plunger in the silver solenoid isnt stuck in the open position.
To understand how most of these work,, lets forget you have an MT walkie stacker and lets say you have a Crown PE electric pallet jack ,,, now your pallet jack will raise kinda slow and when you release the lift button it falls back down without any imput by you. A PE has a similar electrohydraulic setup (but not the "black" flow control),, push the raise button and it causes the solenoid on the pump motor to close supplying voltage to the pump motor which spins the hyd motor creating pressure which causes the lift cyl to extend, let go of the raise button and all stops and holds. To lower the unit you would press the lower button which provides power to the coil on the lowering solenoid (silver solenoid on yours) the coil with + and - supplied now generates a magnectic field which causes the small poppet or plunger inside to shift and open the fliud path back to tank and the lift goes down. A Crown PE system has no provision for the operator to control the rate of raise or lower, its "preset" by the orffices in the valving and controlled electrically it requires no "mechanical" components to function save the function button, a Crown MT has the provision to allow the operator control of rate of raise and lower (black valve).
   / Crown 20MT Walkie forklift (lift-lower valve problem) #19
Sodo,
When looking at this manifold could you check a few items.
1) Is plug "D" directly inline with the pressure or pump supply port. If i would suspect there would be a check valve behind this.
2) Does the drill path below plug "E" connect to valve "F". Does it break into the threaded area of that valve cavity?
3) Does the drill path below plug "C" connect to the black manual lowering valve?
4) Is there a drill connection between the nose of the black lowering valve & the nose of valve "F". I.e if you remove both valve can you see straight through the manifold? Does this passage also connect to tank between these valves?
5) Does the drill path below plug "B" connect to the drill paths below plugs "C"& "E" and also connect to the cyl port?
If yes to all of the above I believe your circuit would either manually lower via the black valve or electrically lower via valve "F". Company i used to work for a had a Big Joe and tested a Crown and both of them had the option of manual lower with infinite speed control or electrically lower at some semi-controlled rate. Yours may not have this feature and work like js5020 says.
Dang I forgot about the lower "button" on the Walkie steering handle. Yes that button operates the solenoid!
Tuesday I'm going to take that valve body all apart and look for a checkvalve, also look closer at the solenoid valve, maybe it's not closing tight. Thanks again you guys I hope you still have some energy for me next week. This weekend I'm on the Kubota (which has NO problems at all aside from being just too dang small)
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
2019 Ford F-550 4x4 Altec AT40G 40ft Bucket Truck (A55788)
2019 Ford F-550...
MCELROY 500 SERIES 3 TRACSTAR FUSION MACHINE (A55745)
MCELROY 500 SERIES...
Adams 5T HC Spreader (A55301)
Adams 5T HC...
2015 Ford F-550 4x4 ETI 37ft Bucket Truck (A55788)
2015 Ford F-550...
BrushFox HD-78STD 78in Rotary Brush Cutter Skid Steer Attachment (A53421)
BrushFox HD-78STD...
