cross over relief valve
/ cross over relief valve #21
Well thats what I have , spring loaded mold board, no cross over valve and in 20 years no issues. I do not have curbs.
well i dont have curbs...but do haved rocks and ice dams at times.
Look what I started.
If I can sum up what I got so far:
If the plow takes a blow that puts a outside shock load on the ram you are smart to put some protection in place to keep the that shock from being transferred into the hydraulic system in the form of high fluid pressure. It makes sense that if you hit the plow high on the retracted side you can't do damage to the hydraulic system because the cylinder has no room to move. Of course expect damage to the FEL or tractor. Something has to give if the plow doesn't trip.
I understand the point about the volume difference on each side of a DA cylinder but I think that is why Prince offers it as a relief/cushion valve. I would have to find out from prince but my guess is that it would cushion the cylinder by expelling fluid from the system........but I'm guessing there. I only say that because unlike air fluid has very little compressibility.
I am as well just plowing two blacktop driveways without higher obstructions but $60 some odd dollars is cheap insurance. If I was only in danger of hurting the cylinder I wouldn't care but I really don't want to do damage to any of my factory spool valves. I'm sure JD would have no mercy on the bill when they replaced them.
/ cross over relief valve #23
That is why you get a spring loaded moldboard.
spring loaded mold board works when you hit something towards the center, has some protection out at the end but does not protect the frame or angle cylinder rod if you hit someting above the tip of the cutting edge out at the end of the blade.
2024 Honda CRF 450RL, VIN:JH2PD1117RK500228 (A61166)
2024 Honda CRF...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2016 FORD TRANSIT T250 CARGO VAN (A59905)
2016 FORD TRANSIT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
