Criticize my welds please
/ Criticize my welds please #21
You likely did delay failure with your welds though.
Unfortunately, it seems that I did not. I had the stabilizer pad sit outside for two or three days, did not use it at all, and the weld is already cracked right in the middle where tho old crack was. I doubt that it is just plain mild steel as my welds usually look better and dont break from sitting outside for two days :D
/ Criticize my welds please #23
Hmmm. Well, sorry to hear that. I welded two pieces of 3/4 in round stock onto one of my legs as a mount for the angle adjusting tube on my BH's thumb and the welds held perfectly. I suppose there might be some sort of alloy in the base metal that could be causing a segregation crack, again, Hmmm.
/ Criticize my welds please #24
This sure is a manly group! :thumbsup::D
I learned stick welding this past summer as some of you know and as globs of my mower deck dripped onto the floor,
I realized a serious amount of skill goes into welding. The OP's weld here remains in my dreams, I made awful welds, somewhat improving,
and wore my arms out grinding off mountains of slag. So to me the OP was looking pretty good, and a motivation for me to step up my welding game from stick.
I have a combo Everlast, just have to get the gas. And since I showed my very first welds to you guys, I remember that the group was kind. Eyerolling was hidden...;)
I admit to wondering where the welds were done by the newbies on the Zumwalt, hopefully above the hull. I bet there are a lot of inspectors,
but as a boater who has done a little blue water, geez when you are away from the sight of land, you sure do depend upon the hull beneath you doing its job.
Watch the YouTube videos of warships out there in Pacific typhoons and as some of those folks are hanging on in their bunks, all those good welds done by caring welders
are sure appreciated. Folks say thank you for your service, those sailors say thank you for those good welds. And good chow.
I think of the guys welding the huge round pipes of pipelines hour in hour out. How does one stay sane/stay focused doing exactly the same thing all day long?
I'd start talking to myself...you're in your own little world there with a giant sparkler in front of you.
I went too fast too, just like the OP. After the bottom falls out a few times I tried to go quicker...
/ Criticize my welds please #25
That weld you put down is completely bad, it is full of crater cracks. You did not move to fast, what you did was made many little spot welds and you started/stopped welding over and over. The stop points are all crater cracks that made your weld... not a weld. It is a perforated line. I am an ASNT NDE Level III inspector at a nuclear facility, I suspect that I may know a crater crack when I see one :thumbsup:
If I saw that weld, I would stop immediately and not even bother to pretend that there is an inspection to do.
I would say to grind that all out, all of it. Mig it again, but this time start once and stop once if you can. Your heat looks decent, wire feed is close, maybe a hair fast. If your welding vertical, and if the weld is trying to run down on you, try making your path down in never ending Z patterns or figure 8 patterns. But you have to get rid of the 100 or so crater cracks before this weld stands a chance of doing any work.
If you can remove the part and lay it flat, you will always do a better job with a MIG. Don't even attempt to weld straight up with a mig! Only the best welders can make that work, and even for them it takes some serious though and practice.
Godd luck. Learning to mig is fun for sure!
/ Criticize my welds please #26
Thanks for all of that. I think by saying "too fast" folks were really talking about what you said better, "keep a steady motion forward" would have been a better way of saying it, as you said, one start, one stop.
/ Criticize my welds please #27
What shows you that you are seeing crater cracks?
Is it the "blob" edge not melted into the one below it?
Im looking at image 907 mostly up close.
Forgive my ignorance. I'm a learner and haven't heard that term.
/ Criticize my welds please #28
You see each weld termination, at that termination there is a bullseye like indication. Many are not a typical minor/shallow indication, instead you will notice a sharply defined bullseye with depth and sharp edges. If you were to do a magnetic particle exam on that weld, almost each one of those would light up like beacon in the night.
Everyone who welds fights the stop point flaw, even the very greatest Union shop welder will once in a while get bit. Heck, if there was 1 or 2 stop points with flaws, on this non critical weld.... It's likely fine. The issue is that there starting/stopping every quarter inch created a massive line of pre stressed stop point crater flaws that together act as a zipper. Go to Google images and your in weld crater crack, you'll see a mess of them in aluminum where the effect is even much more fantastic because of the much more rapid cooling of aluminum that stresses the material higher and more radically cracks the cooling weld, often forcing a very visible star like flaw that in carbon steel is much less pronounced.
/ Criticize my welds please #29
Thank you! Perfect explanation and the Google/youtube tip showed me the phenomenon.
Thanks for taking the time to explain to a newbie.
/ Criticize my welds please #30
Non padded stabilizer pads could be one of the wear resistant AR grades. Not the easiest material to weld anyway. Grind a deep V on the one side, run a nice hot stringer. Flip it over and grind out clear into the weld bead then fill that, one or two passes, whatever it takes. Complete joint penetration that way. Allows for the compression of the weld bead shrinkage. Partial pen on a crack is usually pretty shaky.
/ Criticize my welds please #31
Thank you for that - learning is always good.
/ Criticize my welds please #32
I am a bit north of Belfast so it was 1.5 hours...one way. 15 Hours of commute time per week, 750 hours a year just going back and forth to work. That sucked, but watching the USS Zumwalt sail out to sea was rewarding enough.
I might have always remembered what it was like to make sucky welds, but I also knew why I had to make good welds no matter where I was assigned; 300 sailors that could face battle or 50 foot seas. Good welds always mattered.
The USS Zumwalt broke down in the Panama Canal and bumped the lock wall, likely not any fault of poor welding.
/ Criticize my welds please #33
It indeed appears you were "stacking tacks". Aka pulling the trigger to puddle a single bead, let off, then move, the pull the trigger for the next bead, let off, etc. As Rock Crawler mentioned. Just making repetitive tacks, loosing heat from the puddle, jeopardizing penetration, etc.
That's definitely cast material. The "flame" is from contaminated metal. But hey, it's cast. Prep is everything, Make sure paint is removed from both sides of the material if the material is thin enough. Use acetone to clean any contaminates like oil, etc (that's a lot more important for TIG, but it really does help. any time you're getting a "flame", you're MIGing dirty metal). Anything "heavy" duty, also bevel the weld joint. Or as you mentioned, a groove. Make it a V.
Here are my favorite way's the weld cast: PRE HEAT! use a MAP gas torch or oxy/acetylene with rose bud and get er nice and hot. Next, use stainless wire if you can (i forget the exact explanation, but a long time again when i was welding differential housings regularly, i knew the explanation of why the properties of stainless were preferred when welding cast. the weld will not be stainless after you weld it, since you'll using regular 75/25 gas, but still). Third: directly after welding, shot peen the weld, either with an air chisel pointed end on low/medium setting or harbor freight sells and air needler (stress relieving) Last, slow cooling as much as possible, easiest way is to cover the piece in sand. Bag of play sand is cheap.
Here is my opinion on MIG welding. Someone said always push. That's not true. you push, pull, and stay straight 90 for many different occasion/positions/etc. And actually Pushing keeps less heat in the puddle, pulling keeps more heat in the puddle. (to clarify, pulling is keeping your torch angled more toward the puddle, pushing is keeping your torch angled more to the unwelded joint) You should probably just stay 90/perpendicular to the weld joint to keep it simple and in the center of the joint (unless you have two different thickness of metal, where sometimes you focus more heat on the thicker piece, or change where you keep your puddle/heat based on physical location like it's over head horizontal weld joint)
Next, my preferred and recommended technique is to "whip" the torch. Where you focus the arc to puddle in the absolute center of the weld joint to get full penetration, move slightly forward, then roll/rotate your wrist to "whip" the torch back over the weld you just moved from that is still molten to add a more material. (do this in a slow controlled manner) IN MY OPINION, this is the best weld joint you'll ever make. because you get the full penetration of the weld joint and get a sufficiently large bead, as opposed to sitting in a spot longer to let the weld bead profile build up, where the puddle "spills" abit in the joint just infront of your puddle (as opposed to you moving the torch/puddle there immediately and getting full heat and full penetration).
The whip is the best way to get the "stack of dimes" look. Which was essentially desired from TIG welding appearance. But you still get full root joint penetration. The C pattern, making semi circles, halves moons, or Z's isn't preferred in my opinion. With those patterns you're moving the heat away from the MOST important part of the weld joint, the root. If you need to build up a larger bead then run another pass/stringer up each side of the root weld tying in the material. (or sure, i'm some cases if you know you're running hot enough, you can run a nice large puddle over top of that root; or "whip" by moving forward in to the root and then back up a little extra far if you building up a bigger puddle). If you ever see professional TIG welding, they always do a root pass first, which is a small weld fucosed soley on the weld joint, ensuring the entire weld joint is fully penetrated and fused. Then they come back over top of it with a cover pass to tie all of that extra material in between the two pieces. That's why i stand by the "whip" technique for MIG.
Getting your welder set up properly is the key. Most of these new MIGs have an auto set feature, which you set the voltage, and the wire speed is auto determined.
Are you running .030" wire or .035"?
Regardless of your answer, you'll get a nicer puddle and be able to have better puddle control with .030" wire. So I would you use .030 if you aren't already. That way you can move nice and slow and control your puddle perfect. get full foot penetration and get a nice weld bead also. A good helmet does make a big difference in seeing what you're doing too sometimes.
Get the settings down where you're running enough heat to have a really nice "wetted" puddle, but not too hot that you're burning off the wire.
as everyone says, trying to get the "sizzling bacon" sound of frying bacon. Too hot or not enough wire and you'll see the end balling off as it melts the wire before it gets to the puddle. Too cold or too fast of wire and you'll hear the machine pushing the wire harder/with resistance and your puddle will be colder.
Weldingtipsandtricks.com is a great resource. Jody has a youtube channel and has a lot of useful beginner and expert info. but there are some specific recommendations that may vary from one expert to the other.
my personal preference for a good all purpose wire is Lincoln Super Arc L56 which they sell at Lowes in 12lb spools. i've found cheaper generic or Harbor Freight wire really doesn't weld as nice. it's worth the extra $1-2. IMO.
hope that helps some.
everyone is different.
biggest thing is just doing it frequently enough to establish and maintain the fine motor control of moving your torch properly. that and dailing in your setting properly. I always test weld material or a scrap before hand if it's something important or nice i'm doing the permanent weld on.
check out my thread in the build it yourself forum where i posted recently on the backhoe subframe i made. 0.5", 0.75", 1", and 1.25" material i used. You'll see the beveling, the way the puddle lays in joint, and the bead profile from whip. I weld something once every few months and my consistency with torch control fades quickly in between.
-Haas
MatHaas,
Thank you for your detailed post and all of that information.
Acctually I was using the "cursive e" technique because I had seen it in one of Jody痴 videos. See "welding technique taught by old timer. At least I tried to use it:D
I have a old Esab Migmaster 250. Good machine but no auto set haha.
I am running .035 wire because my machine is set up for .035 and because it was cheaper. I would have to change the contact tip, gun liner drive roll and buy a new spool of wire so I guess I値l hafta stay with .035.
My helmet was also cheap but I have no complaints so far
my personal preference for a good all purpose wire is Lincoln Super Arc L56 which they sell at Lowes in 12lb spools. i've found cheaper generic or Harbor Freight wire really doesn't weld as nice. it's worth the extra $1-2. IMO. I live in Canada so no HF or Lowe痴. I got my wire from a welding supply store. They also had the Lincoln but the guy said it is still good wire and most of the shops have this wire. It was also half the price of the Lincoln.
-Haas
I think I will have my neighbor stick weld the piece with some ni rod. That should be better than the mig.
Again, thanks for your post!
/ Criticize my welds please #35
MatHaas,
yea Jody has mentioned the cursive E in multiple videos, but if you watch any new stuff, you'll hear him say about how he should probably get away from that technique, for the reason i stated.
don't think you should need to change your liner for .030. the feed rollers are usually good for .030-.035; it'll be stamped on it. you only need wire and the tip (in most cases...). But yea, run what you have.
I don't use autoset often, but it is helpful on occasion, preferably on thin stuff. I was just curious if that's what you were using. One of the biggest factors is having the machine set up right. That just comes with experience. I make little tweaks here and there depending on the specific material, but in general know what voltage and wire speed i want for different thicknesses.
Good luck and happy welding!
