Creating a Lake
/ Creating a Lake #2,221
Eddie that's nice work man, as all your stuff is, can't wait to see more of it.
/ Creating a Lake
The cupola is up, but still needs more framing between the ribs and bracing to tie it all together and hold it to the rafters.
Eddie
/ Creating a Lake
Part of the picture in my head is for eaves to be round. I think it's important and if I don't do it, I'll regret it. I wont go into all the details of my failures, but after wasting yesterday afternoon and most of the day today doing it wrong, I figured it out :) Now I get to spend all of next weekend doing the other three corners.
Eddie
/ Creating a Lake #2,225
It's looking good Eddie. Complicated...but in a good way. :thumbsup:
/ Creating a Lake #2,226
Looks great...when will you start supplying kits for sale:D
/ Creating a Lake #2,227
Eddie,
Definitely, definitely a labor of love.
hugs, Brandi
/ Creating a Lake #2,228
WOW
another hit out of the ballpark
INCREDIBLE
/ Creating a Lake #2,230
Eddie, how many times did you crawl up that ladder? Seems almost every board was a special cut. Waiting to see the roofline. Your roof might be mis-viewed as some sort of deep space antenna by a satellite. :)
/ Creating a Lake
I'm finally done framing out the eves. Going round is something new for me, so the learning curve slowed me down quite a bit. While walking past it, I looked up and liked the way the light was shining on my rafters, so I took this picture.
My decking is going to be 1/4 inch OSB that I'm going to put down in two layers with overlapping seams. Since my rafters are 16 inches on center, I'm hoping that should work out. What I'm not sure is how much bend I can get out of a full sheet and if I'll have to rip them in half or even four pieces 1 foot by 8 feet. I don't have a choice, so it's probably going to be a combination of all of the above.
Eddie
/ Creating a Lake #2,232
Eddie
You are getting close to being in shipwright territory with the roof on this project...quite impressive:thumbsup:
/ Creating a Lake #2,233
Eddie, what if you cut 1/8" depth every 1/4"- 1/2" or so in the OSB? may allow the sheet to bend more. Sure would be a PITA. but I bet it would help it flex.
Looks good so far!
/ Creating a Lake #2,234
Looks good so far!
/ Creating a Lake #2,235
Just throw the OSB in the lake for a day. It would follow all the contours then. Lol
That is a spectacular structure. I must make sure my wife never sees IT !
/ Creating a Lake
I'm getting down to the final decision on what to use for shingles. I don't want the main roof to be the same as the cupola. What would you use, and where would you buy it?
Eddie
/ Creating a Lake #2,237
Cedar plank and dark shingles would go good with the cedar post, or shiny tin and cedar planks.
Copper would be the "bomb"!!!
/ Creating a Lake #2,238
I think cedar shake would look dramatic on it. Keeps it with the organic flavor of the curves. Kind of looks hobittish!
/ Creating a Lake #2,240
I also think Cedar shakes are the way to go. They can be conformed to the unique design you've made, are true to the influences from your travels that I believe influenced your design and will last with little maintenance for years. Whatever you decide I look forward to seeing the end result.
MarkV
1819 (A64557)
1819 (A64557)
ALLMAND  MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
2014 CHEVROLET CAPRICE CAR (A66091)
2014 CHEVROLET...
1999 TRAILMASTER PUP TRAILER (A67714)
1999 TRAILMASTER...
ALLMAND NIGHT-LITE PRO II (A68842)
ALLMAND NIGHT-LITE...
