Creating a Lake
/ Creating a Lake #1,061
As the rain continues off and on in our part of Oklahoma the ground has begun to saturate and each succeeding inch of rain is more run-off than soak-in. Several of my pastures have areas with running surface water. I have little level land and in general it drains pretty well but now it is getting more than we can use.
All the ponds near the house (7) are overflowing. The smallest of the 7 has the largest drain pipe (30 inch) and it is staying 1/2 full so far this morning. The two ponds with 12 inch diameter drains are full and overflowing at their "emergency" outlets. I try to always have a swale to take the overflow away from the back of the dam so that in these heavy water events the dam is not harmed and it is all working to plan right now.
I noticed a curious thing this morning on my walk. About 6-10 feet from the dam of one pond (out in the pasture) there was something moving in the grass in the approximately 1 inch of water running through toward the pond. I thought OH GOODY, TADPOLES but it was mostly bluegill fry about 1 1/2 to 3 inches long (maybe some crappie also but they didn't exactly pose in plain sight for a picture as I stomped through in my rubber boots. As I turned and walked up the slight incline to the next pond (couple hundred feet) I noticed considerable runoff from this little drainpipeless pond. It overflows in a wide area of grassy pasture and does not erode the land as the water flows down to the larger pond.
Anyway I saw what at first seemed to be dozens of fry then hundreds and then thousands!. They were swimming out in the pasture at times a hundred feet from either pond. Surely there will be a stranding of considerable numbers and the birds and other critters will have a feast. The water they were in was from 0 to 1 or 2 inches deep and was a mixture of the pond water from where they "escaped" and run off flowing down slop[e toward a pond.
So much for mono culture in my "catfish" pond stocked only with channel cat and fat head minnows. The pond upstream of it will no doubt "seed" it with some of whatever it has in it. Hopefully I won't loose too many catfish from that pond, through the next two and on down the creek off of my property.
Pat
/ Creating a Lake
Pat,
Sorry to hear about all the water you guys are getting. The forecast looks like it's gonna be this way all week. We're getting a short afternoon storm every day, but it's less then a quarter inch. Nice for watering the grass, but nothings going into the lake.
When the lake is low, I wish for massive rains, but when I hear about your runoff and overflows, I'm reminded of all the damage those rains can cause.
I'd love to see some pictures of those culverts and emergancy spillways flowing with all that water!!!! Is there any concern for your dams integrity? Water saturation or erosion?
Good luck to you and I hope your fish make it through all this,
Eddie
/ Creating a Lake #1,063
Eddie, That was the reason I went for a walk through the fields. I was inspecting the dams, drain pipes, emergency overflow swales and such. I did take pix and they are posted on CBN under "Raining Fish."
My quarter section has the 1000 ft contour meandering through it and we are nearly a mile and a half from the river. We have no flooding problems at all. Long before we have a rising water problem lots of nearby folks are going to be discussing cubits and pairs of animals. Everything is filling up and the ground is saturated at the surface but so far we haven't made up for the loss to the aquifers over the last couple years (including last years record drought.)
Pat
/ Creating a Lake
Pat,
Great pictures!!
I really like the vortex of your culvert that's under water. I can sure see how that will suck up some of your fish and flush them out of your pond!!!!
It took me a bit to find your thread, so here's the link if anybody else wants to see your pics.
CountryByNet.com Forums :: Raining Fish?
Eddie
/ Creating a Lake #1,065
Eddie, Of course the thousands of fry swimming in the pasture were not sucked up by a drain pipe and were just flushed out by overflow over the bank of the pond. Yes, I agree regarding the vacuum cleaner effect of the whirlpool. By the time a fish feels the pull it is too late to escape and so any fish near the inlet of the drain pipe will get a fast ride to the next pond in the chain.
The good news is I didn't see any catfish in the swale from my catfish pond. That could be bad news I suppose as in the fish were all washed away already but I don't think so. I will go toss some floating catfish food in and see who responds.
Pat
/ Creating a Lake #1,066
Mornin Pat,
As Eddie said those were great pictures ! Thanks for taking time to post them. Couldnt get over how green things are out there ! How long before your pastures start to brown up fron the excessive heat ?
/ Creating a Lake
Scotty,
I don't know about Pat and his conditions, but here the grass stays green from spring to the beginning of winter. We don't water our grass, and it thrives in the heat. It will go dormant in the winter when it freezes outside, but it's only brown during the winter months.
Eddie
/ Creating a Lake #1,068
Scotty, The most predictable thing about Oklahoma weather is its unpredictability. I haven't a clue any given year when it will get hot and dry and brown out the grass. It is pretty variable. Year before last was a drought and last year was a
D R O U G H T
It was a record drought exceeding those of the infamous Dustbowl era, Grapes of Wrath stuff. Different farming styles than in the old days is what prevents the "dust Bowl" effect. The rain we are getting has saturated the surface dirt so we get lots of runoff but the aquifers are NOT recharged by a long shot.
Our typical summer rain is thundershowers. If you get some then fine but if you are missed then oh well... We will be a lot dryer in August, probably, but no guarantee. We typically brown out but I can't promise we will before fall but it is LIKELY.
Looks like Ireland now or the sheep lands of southern England down by Petersborough.
The adventure continues...
Pat
/ Creating a Lake #1,069
EddieWalker said:
Dragonfly nymph?
This is a new one for me, so I googled it and got me a little education on dragonfly's. I had no idea of how they come about, but never even considered that they live in the water before turning into dragon flies!!!!
None of the pictures I saw were an exact match to what we cought, but they are close enough to show me that's what it was. Weird little creature, but kind of cool too.
Thank you.
Eddie
Eddie, Think back... was the thing you saw, which wasn't that good of a match, any thing like the picture attached to this post? I had to do some powerful recalling but I think this is a likely suspect.
This critter is a helgramite and I think IT IS WHAT YOU SAW. Google for other views.
Pat
/ Creating a Lake
Pat,
It's similar, but I think the dragonfly nymph is closer. All the pics and links for Helgramite's look the same, but there are so many different pictures of dragonfly nymphs that seem allot closer. Another thing is that we have allot of dragonflys, but from what I've seen of the hegramite pictures, or whatever it is after it comes out of the water, I've never seen one in it's winged state.
Thanks,
Eddie
/ Creating a Lake #1,071
Neat thing about ponds, you build one and pretty soon new and wonderful living creatures are all over the place.
At least it wasn't a snake nymph!
jb
/ Creating a Lake #1,072
Eddie, The Texas state extension info says the Dobsonfly is quite common in Texas. The Dobsonfly is what a Hellgramite becomes long enough to mate.
Dobsonfly
If what you netted isn't a larvae of a Dobsonfly, you probably still do have them about as they are so common, just not as pretty, nifty fliers (natures helicopters) or as long lived as the dragonfly.
If you net another copy of the same looking thing, check the head end carefullyu for mandibles. The hellgramites can bite you.
Pat
/ Creating a Lake
Pat,
That link is better then the ones I found, but it also says "Hellgrammites are aggressive predators that attack other aquatic insects and other organisms in the water. They are found in flowing rivers and streams hidden among rocks."
The spelling is different for it on that site, but the main thing is they seem to be in moving water of allot better quality then my muddy colored pond. I've never seen anything like what is described, and I have allot of weird bugs that come to my lights at night!!!
I searched that site for dragonfly nymphs. Damselfly and the picture they have is very close to what we cought. Same number of legs in the same area. Same looking front end and body. The heads are differnet with thier eyes not being the same and the ends of there tails do not match. The tail think could be that the one we cought was out of water and it was just held together. I don't know.
It's very, very similar and we think it could either be more mature then the one in the picture, or just a differnty type of dragonfly. We have three types that we know of, but the link I just provided doesn't show two of them. It just has the most common one.
Thank you,
Eddie
/ Creating a Lake #1,074
Eddie, you do not have a Hellgramite there, they live/grow in clear rock bottom rivers like Guadalupe river, Medina river, frio...etc. I have used them for bait, they are mean tough little bugs, great for bait, hard on fingers:)
There is one thing I can't explain though....I have seen two Dobson flys at my place in the five years I have lived on my place and there are no Helgrimites within 150 miles of me:(
/ Creating a Lake #1,076
I would think so or the fly version doesn't need clean water...only a good tail wind:)
/ Creating a Lake #1,077
EddieWalker said:
Pat,
I searched that site for dragonfly nymphs. Damselfly and the picture they have is very close to what we cought. Same number of legs in the same area. Same looking front end and body. The heads are differnet with thier eyes not being the same and the ends of there tails do not match. Eddie
Eddie,
There are many species in the dragonfly-damselfly family. There are also many species of flies in the lacewing family, such as the Dobson fly, may fly, stone fly, caddis fly, etc. that produce aquatic nymphs. All of the above nymphs can look roughly similar, but differ according to the exact species. They will always have some common features according to their family, but other body parts can be a lot different. The field guide may have shown 1 type of dragonfly nymph, and you caught another.
/ Creating a Lake
Gary,
Thanks.
It's hard to believe that this thread has been viewed so many times. I guess it's taken on a life of it's own and I'm just the guy who started it. There has been so much information shared and ideas discussed in it that it's become thread about all of us, and not just my lake project.
Eddie
/ Creating a Lake #1,080
This thread has covered land clearing, earthmoving, heavy machinery overhaul, landscaping, site development, and botanical and biological items. some of them (like heavy machinery overhaul) were topics that came uninvited when Eddies dozer broke down, though we all loved to follow the progress and setbacks of the project...
Why didnt they broadcast this on TV, this would be a soooo much better "real life soap" than most of the "americas next top model" garbage that my mother and sister want to watch, when i want to watch discovery channel :D ;) :)
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
1995 FORD F-SERIES S/A GRAIN TRUCK (A64278)
1995 FORD F-SERIES...
JCB 3TS-8T Compact Wheel Loader Skid Steer (A64553)
JCB 3TS-8T Compact...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2010 Brenner Aluminum 407 T/A Chemical Tanker Trailer (A64194)
2010 Brenner...
Ground Protection Mats (A64194)
Ground Protection...
