Create garden Kubota 3030 or JD 3720 or miniloader Avant
/ Create garden Kubota 3030 or JD 3720 or miniloader Avant #1
wolodi
I will start my own business which consist on create gardens(cerating lawns, plant shrubs, ponds etc.) and clear of snow on winter. So i need some machine to do that. I must have loader and backhoe. I think about kubota 3030 or JD 3720 with fronloader and backhoe of course or mayby better to do this will be miniloader like AVANT?But I dont know anyone who use AVANT loader (Kubota and JD are well known for everyone). Avant can be use also to unload something using forks (I think about 520 series). I dont knows what to do. Maby sameone could help me>
/ Create garden Kubota 3030 or JD 3720 or miniloader Avant #2
Why a backhoe? Many lawn companies use skid steer loaders. Much more able to get into small areas than a tractor with loader and hoe.
Must companies also have a dump truck and trailer to haul equipment to the site and to haul materials to and waste from the site.
I know a guy that has been doing a lot of what you posted, but he just uses hand tools, push mower and push blower. Low overhead is a good thing.
/ Create garden Kubota 3030 or JD 3720 or miniloader Avant #3
if you get a front end loader on your tractor with skid steer quick attach bucket you'll be able to easily remove the bucket and put on forks for picking up pallets.
Depending on the size of the project you want to do you might need larger (or smaller) tractor/backhoe/excavator. You might want to consider renting your equipment for awhile until you get a better handle on what will work best for your situation.
2008 MACK CHU613 TRI AXLE 16FT DUMP TRUCK (A58018)
2008 MACK CHU613...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2020 GMC AT4 CREW CAB TRUCK (A60430)
2020 GMC AT4 CREW...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
New Holland 3930 (A60462)
New Holland 3930...
FORD F SERIES DUMP TRUCK (A52707)
FORD F SERIES DUMP...
