Cranking JD H model HELP PLEASE
   / Cranking JD H model HELP PLEASE #1
jneville
DeWitt, VA
H JD
I have a Model H JD, serial# H61020 that was setting for years. The engine was seized but after soaking with transmission fluid and PB blaster it turns freely now. I am not getting any spark to the plugs. I am trying to figure out the fuel system also as I am sure the carbeurator is not working either. Any information on getting this tractor running would be greatly appreciated.
   / Cranking JD H model HELP PLEASE #2
:welcome:
I'd first work on getting a spark. Track back through the system, to find out where the problem might be.
Is this hand crank? or electric start?
If no spark, I'd suspect bad plug wires or bad/dirty magneto.
Here is a link that may be helpful to you as well.
http://www.jd2cylservice.com/
electric start
   / Cranking JD H model HELP PLEASE #4
Ok, now to get spark. No need to do any carb work (other than know that fuel is reaching the carb) until you get spark.
2021 International HV507 4x4 12ft Single Axle Dump Truck (A54814)
2021 International...
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
2003 FORD F350 XL SUPER DUTY DUMP TRUCK (A51406)
2003 FORD F350 XL...
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
