Crank Seal
/ Crank Seal #1
Fornshell
JD2240
Can you install a JD 2240 Crank seal without special tool.
/ Crank Seal #2
It looks like it is similar to this seal replacement video and I think it would be tough to do it without the tool. The seal must push in hard because it is a press fit in the block and on the crank and it must be installed straight.
/ Crank Seal
Yes I watched that video. Expensive tool for one install.
/ Crank Seal #4
There are a bunch of non-deere seal installers sold online. Will a shop loan/rent one to you?
/ Crank Seal
Ok thanks I'll look online.
/ Crank Seal #6
You can partially install it using the flywheel. Then you know it goes on straight. You'll have to tap it the rest of the way in though. If you're careful you can get it in there without getting it cockeyed.
Alternatively if you have access to a lathe you can make your own
/ Crank Seal
Thanks for your help,that's kinda what I had in mind using the flywheel.
/ Crank Seal
Ok thanks for the information, will look it up
/ Crank Seal
I bought the rear crank seal from JD. They say this seal requires the special tool for installation or it will leak.I found one online for 133 dollars, guess I'll have to get it . Don't want to split it again and waist a good seal.
/ Crank Seal
Received my rear crank seal installer tool today, And the pilot piece won't bolt to the crank. But tool seams the right size for the seal.
/ Crank Seal
Can anybody help me out on a part # for this tool. JD 2240 Rear crank seal installer. I ordered one for DZ111672 seal but the pilot piece won't lineup with crank.
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2022 EZ-GO ELITE...
2022 John Deere 5100E (A64126)
2022 John Deere...
Woods 72" Brush Cutter (A64047)
Woods 72" Brush...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
3143 (A63117)
3143 (A63117)
