Cracked steering wheel
/ Cracked steering wheel #1
Boss 302
Platinum Member
Va.
Kioti RX6010PS Mahindra 3510 Sold (Gonna miss that ole girl)
Within the first couple of years of owning my RX the steering wheel developed a crack, it was replaced under warranty. Now about 6 years later this one has 2 cracks, I believe what happens is the resin shrinks and causes it to separate. I'm in the process of attempting a repair with stick epoxy. Anyone else with this issue?
/ Cracked steering wheel #2
How is the steering wheel made? Many steering wheels are based on a ring of steel. The plastic or resin simply coats it. If that's how yours is made you could just get a lace on steering wheel cover to hide it.
It's resin over a steel ring like most others are made. I would rather not use a cover, pretty simple to fill in with epoxy.
/ Cracked steering wheel #4
I had issue of the cracking 2016 and they replaced under warranty. Said it was a supplier issue but was supposed to hAve been fixed. No issues since and mine is out in the weather all the time
Thanks Woodchuck, I was wondering if they had taken care of the issue with the newer tractors.
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
(2) 15.0/55-17 TIRES W/ 6 LUG RIMS (A64280)
(2) 15.0/55-17...
2015 FREIGHTLINER CORONADO 122 SD (A67714)
2015 FREIGHTLINER...
2017 Autocar Xpeditor T/A New Way 31ASL 31yd Side Loader Garbage Truck (A66736)
2017 Autocar...
DEUTZ FAHR 4080E TRACTOR (A65057)
DEUTZ FAHR 4080E...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
