Cracked instrument console
/ Cracked instrument console #1
joe04785
Maine
XR3037
Anyone ever run into this problem?
/ Cracked instrument console #2
In that second pic. Joe looks like something banged it with that crease next to the crack.
/ Cracked instrument console #3
Don't know how old your tractor is, but that looks like a job for your soldering iron. Drill a small (1/16th) hole at the terminus of the crack( to prevent it from growing) and thermal weld the crack
I'm not sure exactly what happened there. The tractor was at the dealer a couple months ago, so maybe it happened while it was there. I went to see the dealer and ordered another console under warranty. The tractor is a 14 with 50 hours. Just very odd at how it is cracking.
/ Cracked instrument console #5
When you re install, look at how it is supported in the area. Maybe there is a ridge, or it is left to flex which is bad. Good luck. BTW - do not over tighten the mounting bolts either. On my Bobcat I used the soft Locktight and just snugged it up.
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
2013 Ford Explorer SUV (A64557)
2013 Ford Explorer...
2019 DITCH WITCH TOWABLE VACUUM TRAILER (A63276)
2019 DITCH WITCH...
2015 Ford F-250 Ext. Cab Pickup Truck (A64556)
2015 Ford F-250...
Used Landpride GR1525 Stump Grinder
Used Landpride...
1995 Landoll 55 Ton Trailer (A60352)
1995 Landoll 55...
