Crack in cast iron stove?
   / Crack in cast iron stove? #31
Shield Arc said:
Oh, dealing with cast iron repairs can be a crap shoot at times! I've had days repairing cast iron and T-1 where I just wanted to set down and cry!
I hear that! I won't even touch cast iron anymore.
   / Crack in cast iron stove? #32
Yeah, and you just barely used enough preheat for stick welding. Lincoln suggests 500 to 1,200-degrees, and 900 to 1,200-degrees for O/A welding, and never let the object get over 1,450-degrees.
Here is a really good book on welding odd ball material.
Man in the little bit of cast iron repairs I have done, my method was just O/A, and brazing rods. Sat the cold part on the floor, hit it with the flame until it was cherry red, brazed it, and left it on the floor until it was cold. Mind you this was a cheep cast iron dumbell, with about equal parts iron and porosity, no surprise it failed the hammer test. I am sure I spent more on gas then the thing cost, I was new to welding, and wanted to try fixing cast iron. That casting was so bad, I am not sure there is any way to do a strong repair. (I think duct tape would have been better then welding (see my sig line)) All this cast iron repairing stuff seem so confusing to me.
   / Crack in cast iron stove? #33
Like ShieldArc said, cast iron is usually a crap shoot. You find out quick if its gonna be a go or a no. your pics wouldnt open on my phone, but if it didnt beat you down on the repair, I would say you should be fine. I recentley did a job very similar to yours, accept I fabbed a new ear out of mild, and welded and blended to cast, and havent heard anything about failing yet and the guy lives local. I think you should be fine bud.
It seemed to weld ok but was not aligned right for the hinges. So I'm giving it another go with a threaded rod to align the hinges.
Well, it worked great. The hinge lines up and operates corrrectly.
And here she is doing her thing.
   / Crack in cast iron stove? #38
All right....Just think how much you learned and how much easier it will be next time..:thumbsup:
   / Crack in cast iron stove? #39
Great job now how did the ribs turn out?:D
Ha ha, the ribs were burned at 600 F!
Thanks for the help and ideas guys.
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A56858)
2006 International...
60in Forks (A56857)
60in Forks (A56857)
2020 Peterbilt 367 Weldco Hydra-Lift WHL45TC100 45 Ton Tri Axle Telescopic Crane Truck (A55973)
2020 Peterbilt 367...
2025 Swict 66in Bucket Skid Steer Attachment (A56857)
2025 Swict 66in...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
