Crack in Bush Hog Gearbox
   / Crack in Bush Hog Gearbox #21
I remember when bush hog went to those china boxes, they had LOTS of bearing failures...
The very next rotary cutter I bought, I went away from BH on UP to Woods... That was one of the BEST moves I've ever made!!
BTW, it was the deck that got all cracked up on my BH rotary cutter!
I have nothing but GOOD things to say about my Woods cutters!
SR
JWR, I know this is an old thread. Just wanted to let you know that my BH296 cutter has failed in the same place and in the same fashion. I own a fab shop so I have already repaired the casting with nickel rods but I can tell you and Bush Hog exactly why it failed...... Although, from the outside, the casting looks very beefy and thick, the lower side wall of the box is less than 1/8" thick in some places. Way to thin for this application!!! As you know, the base mounting flange on the gearbox is about 7/8" thick then it immediately transitions to 1/8" thick up the sides. When welding a crack in cast iron it is standard practice to drill a hole at each end of a crack to help prevent the crack from continuing on after the original crack is repaired. I was expecting the sidewall to be at least a 1/4" to 3/8" thick when drilling but the bit unexpectedly punched right through the side with no trouble. ...
QUOTE]
Mr. basicequipment -- that is a huge help on this issue !! Great work and thanks for taking time to let us all know. I would bet that Bush Hog themselves would really love to hear your story and what you found. When I had lots of contact with them in 2015 I think they genuinely DID NOT KNOW why the failures were happening. They told me then they had "seen this before" and neither they nor their supplier could explain it. I say you just explained it big time. In spite of the dealer (central WV) bad mouthing me and accusing me of abusing the hog, the company backed it fully and told me they would have backed it with this type of failure no matter whether it was under warrantee or not. I'd like to see you have a good conversation with them and explain what you found. I expect first, that they would thank you, and second that they would support the product long-term. If you do all that let us know. Contact at Bush Hog is Chris Cook at chris.cook@bushhog.com email. You can message me through TBN with your email address and I'll be glad to send you copies of my correspondence with Chris Cook. Thanks so much for shedding serious light on this issue !
[By the way: After Bush Hog replaced the gear box I have put at least another 50 hours on it with no problems. At least not gearbox problems. I have had to tighten the big center nut holding the stump jumper on to the gearbox main output shaft a couple of times. I am generally clipping pasture fields and some autumn olive brush clearing but rarely cutting anything all that thick.]
   / Crack in Bush Hog Gearbox #23
JWR, thanks for the email address for Chris Cook. I will reach out to him with my findings to see what he has to say. I will message you my email address. I agree, aside from the crack, this has been a great cutter. It is interesting that your stump jumper keeps working loose. I'm sure they have a torque spec listed somewhere for the castle nut. If torquing it to the correct spec did not fix the issue, you could try adding a lock washer or belleville washer beneath the nut to keep a more constant tension if the washer will fit and still allow you clearance to re-install the cotter pin.
CaIG, you are correct, a little modification to the mold would have solved there whole problem, unfortunately they probably already had several thousand mowers out in use before the issue showed up. Thanks guys! I will let you know what BH has to say. I hate to say it but I completely understand why they went to China for castings. Our big government killed the steel industry in the US a long time ago. Now American manufacturers, workers and consumers pay the price.
   / Crack in Bush Hog Gearbox #24
Just wanted to update everyone....Bush Hog and JWR came through for us. Thanks to JWR, I reached out to Bush Hog and explained that we had the same issue with our gearbox cracking. I emailed them a few pictures along with our serial # and they assured me they would make it right. We had to wait a few weeks because the gearbox was on back order but as soon as more arrived at the factory we received an email and tracking number letting us know that our box was on the way. Now that to me is top notch customer service. I am now a long term Bush Hog customer!!! Thanks again JWR!
You're more than welcome. It is worth a lot to be able to communicate on such issues. I have much respect for Bush Hog and appreciate the way I was treated.
   / Crack in Bush Hog Gearbox #26
This is a refreshing post! 2 satisfied, happy customers and a "stand up" manufacturer!:thumbsup:
2013 MACK CXU (A50854)
2011 L3 MEP-806B GENERATOR (A51222)
2011 L3 MEP-806B...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2015 VOLVO ECR88D (A50854)
2015 VOLVO ECR88D...
2006 BOBCAT S130 SKID STEER (A51222)
2006 BOBCAT S130...
2020 INTERNATIONAL LONESTAR TANDEM AXLE SLEEPER (A51222)
2020 INTERNATIONAL...
