Counterweight
   / Counterweight #1
metalbender
Sask, Canada
Massey 1742
A new project for the Massey. Looked at many diy weights, came up with a compact version. Short history. A few years ago, I was involved in the lead wheel weight frenzy. With all the do-gooders frowning on lead, pressuring governments to ban them and go to steel, I salvaged and melted down about 800 lbs for future bullet casting. So with all that sitting idle, cast into one pound ingots, might as well put it to use. One cubic ft of lead is just over seven hundred lbs. My ammo can has more than enough volume to get a substantial weight in a small package. Made to work with the quick hitch. 726CB216-D053-4F49-AD3D-D93AC8C5B6AB.jpeg
   / Counterweight #3
[insert beer icon here]!
   / Counterweight #4
Nice! WoW - you have cast 800# into one pound ingots.
   / Counterweight #5
When I did SCUBA we'd cast our own 5 lb belt weights from old lead pipe that we'd find at yard sales etc.
My stock of belt weights mow get added to tractor ballast.
My compact main weight is a 300 lb cast iron elevator weight. (it is narrower than my rear wheels and about 5" high X 10" deep and is slung from the 3 point arms, also serves as hitch for trailers)
LOL, combined with studded rear chains I NEVER get stuck! (but sure can dig a deep rut if not careful)
Don't ask for pics as presently the weight is under 3 ft of snow since the blower has not seen the last of winter quite yet.
   / Counterweight #6
Didn't have any wheel weights so went with concrete... Frame made of old angle iron bed rails and some 10 gauge steel sheet... 8 - 60lb of quick mix bagged concrete... Found out old rattle can caps fit 2 inch ABS pipes (tool holders) really well to keep crap out of pipes...
Dale
   / Counterweight
I lied, looked at my stash, found a couple hundred lbs not yet processed. Weighed the good stuff. Another get round to it job. 498E8915-05E5-49E4-82C8-2C938AE9B556.jpeg
   / Counterweight #8
I am going to make one out of concrete soon but you have a good idea.
I really like how compact yours is and still be very heavy.
   / Counterweight #9
A new project for the Massey. Looked at many diy weights, came up with a compact version. Short history. A few years ago, I was involved in the lead wheel weight frenzy. With all the do-gooders frowning on lead, pressuring governments to ban them and go to steel, I salvaged and melted down about 800 lbs for future bullet casting. So with all that sitting idle, cast into one pound ingots, might as well put it to use. One cubic ft of lead is just over seven hundred lbs. My ammo can has more than enough volume to get a substantial weight in a small package. Made to work with the quick hitch. View attachment 597578
I have about 800 lbs of used sheet lead.
Would like to find an easy way of melting it, and what to use for a casting mold....5 or 10 lbs each
   / Counterweight #10
...I have about 800 lbs of used sheet lead....
A good use for sheet lead is making EMP proof containers...you never know...!
   / Counterweight
For good molds, local thrift store, old bread pans or anything similar.
   / Counterweight #12
Nice. Very compact for it's weight which is great!!!
If you aren't too far,,, I'd suggest locating the lift pins so you can set it down anywhere. In the pic you won't be able to set it on the ground and get unhitched.
I often pick up my counterweight, do a five minute job, set it back down, never leave the seat, no special unhitching process required. :)
   / Counterweight
It might just have enough distance from the pins to the bottom, a couple of concrete blocks would make a good parking spot. In my effort to keep it close to the tractor, the hook interferes with the lift process. I'll have to do the top pin as a separate step. Not a biggie in my book. I'll see if it's an annoyance.
   / Counterweight #14
Most tractors won't lower the quick hitch to the ground. By your pic the weight frame and quick hitch are both sitting on the bench. That was my concern. If you don't mind always dropping the weight in the same location it'll be fine.
I prefer being able to drop any attachment anywhere. I'm too spontaneous for precise locations. :)
   / Counterweight #15
I am so old I do not think I need to worry about that!
   / Counterweight #16
What heating source, and container, to actually melt the lead?
   / Counterweight #17
You can use a rosebud on a OA torch, or even a propane torch - or a barbeque or a fire. I used to have an old electric range I used. A forge is ideal.
Make very sure you have clean fresh air to breathe. Wash thoroughly after exposure. Realize that lead builds up in the body.
I have been involved in shooting and reloading as a hobby for over 40 years. Remember when they outlawed lead paint? The research on lead poisoning is deep and scary. Knowing what I know, I handle lead with care and NEVER melt it. It's just not worth it to me. I'm getting ready to build a counterweight, and will use concrete.
I'm sure someone will be along and tell us how safe a boiling pot of lead really is. Just remember, lead exposure can cause irreversible brain damage...
From WebMD:
Often there are no obvious symptoms of lead poisoning. But if you’ve been exposed to lead over a long period of time, you might experience any of the following:
Permanent brain damage
Anemia (decreased red blood cell production)
Hearing problems
Reproductive system damage (men and women)
Kidney disease
Seizures
Coma
   / Counterweight
Counterweight done. No fun transferring all the ingots one at a time. Prob have room for a couple more layers. AB25DF3B-9400-4E1C-9A65-D5BD412C9944.jpeg24DA6503-2827-499B-963E-CA0FDE60265D.jpeg
   / Counterweight
Regarding melting the lead, I made a small heater assembly using a water heater burner, running on propane. Doing it outside, downwind is ok. You are not boiling the lead, causing vapor, just bringing it to the melting point. Melting point around 620 F, boiling point 3150 F. Use a high temp thermometer to monitor.
   / Counterweight #20
I believe these were used for garage door counterweight's. They (I have two) are lead filled and weigh 200# each. They measure 32" x 7" x 3" thick. Of course I welded the bars on for 3 pt. each
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
UNUSED IRANCH 20CM TOOTHBED MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 20CM...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
CASE 586H ROUGH TERRAIN FORKLIFT (A60429)
CASE 586H ROUGH...
2025 CE SB05 Hydraulic Breaker Mini Excavator Attachment (A59228)
2025 CE SB05...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
