Countdown to Plug in Hybrid CUT?
   / Countdown to Plug in Hybrid CUT? #31
It would surely seem that way, but if you dig deep enough, reality has a cruel and perverse sense of humor. It turns out that theres a lot of coal generation upwind from us Nutmeggers and there is 100% chance that we suffer, directly, from the fallout:
New Report: Coal Power Plants Release Huge Quantities of Mercury, Polluting Streams and Rivers Nationwide - Jonathan Kantrowitz - Connecticut News
Until you fully understand the agenda, behind the link you posted, you will fall for any such blog post as that link.
But to keep in context with your original post, that I commented on. You do not "wake up smelling clean coal in the morning"
   / Countdown to Plug in Hybrid CUT? #32
I would guess that the Koch Bros.' scheme is to make enough money for them and theirs to escape the planet and not come back until the rest of us, and any other surviving species, have evolved and mutated to the point where mercury is good for us, then return to get the gene spliced into them.
Search term for today: "Breakaway Civilization"
   / Countdown to Plug in Hybrid CUT? #33
Presumably this is not the case or some smart fellow at John Deere would have already invented it.
Look up "LeTourneau", these guys have been making diesel electric equipment since just after WWII, mostly for forestry and mining, though there was also that "land train" thing. You'll notice the engine compartments on their machines are still plenty big. The best way to think of a straight non-battery (or flywheel, hydraulic accumulator, air compressor, or whatever other energy storage you might use) diesel-electric is that it doesn't replace the engine, it replaces the transmission and driveline. The raw power to start with (and the fuel consumption) will be about the same. You gain a few % on efficiency, wear and tear, and operating costs.
What batteries allow you to do is to take less output over a longer period of time and release it in short bursts. Also, a car operating at steady speed doesn't need nearly as much power as it takes to get it up there, which makes the battery setups a good match. For a constant heavy pull, you're out of the area where the batteries do well. And without the batteries, you still need all that power available at once--regardless if it's gears, a hydrostat, or a generator and traction motor in between the engine and tires.
For just running light errands such as moving wagons around, yeah it might make sense--so would having a smaller more efficient machine around to do those errands. For running any sort of powered implement (mower, tiller) or ground engaging tool (plow, harrow) not so much.
The tractor I see most used to do an electric conversion is an Allis G. Before conversion, this tractor puts out about 8hp (drawbar, 10 belt) stock, and is mostly used for cultivating...pretty light duty, and not a bad matchup for electric.
If you just need to carry yourself and a few tools around, how about a battery golf cart? If it will make you feel better, you can get ag lugs for them...
12' CONTAINER (A52706)
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
2015 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2015 Kubota...
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
