Countdown to Plug in Hybrid CUT?
   / Countdown to Plug in Hybrid CUT? #21
Seems like we can't have a discussion anymore without political potshots.
:confused2:
Well, it's pretty much a purely political subject.. :D
Chevy Volts aren't selling. I guess unless someone wants to build their own to make a point, which has been done, then what's to talk about?
   / Countdown to Plug in Hybrid CUT? #22
I just read that Costco is removing their car charging outlets because nobody but Al Gore was using them. They were probably sick of him dimming their lights when he plugged in his SUV.. :laughing:
:D:D:D:laughing::laughing:
   / Countdown to Plug in Hybrid CUT? #23
Seems to me that the hybrid answer is best for a tractor. I'm not an engineer but the way I envision it would be a very small, high efficiency diesel engine that can run a generator and maybe the hydraulic pump/s at a fairly constant speed. A large electric motor would drive the wheels and PTO. No batteries except to start the diesel.
The issue, for SCUT and CUT owners is that you'd pay a lot for this machine and for most weekend warriors there would be no significant cost savings. And the complexity would be a minus too. My tractor fuel costs are hardly worth mentioning at maybe 50-60 hours a year on a 45hp machine.
I think the hybrid described above would be better for big machines that run all day long. The idea is pretty much how a diesel locomotive works, just scaled down a bit.
   / Countdown to Plug in Hybrid CUT? #24
You must be an engineer. What you just described is, well, a tractor. A small, efficient diesel engine turning a hydraulic pump and an alternator. The only reason a diesel locomotive operates this way is for torque. A hydraulic motor would have to be 100' in diameter to get the same torque.
   / Countdown to Plug in Hybrid CUT? #25
You've confused me. Not hard to do, so don't feel bad.
My thinking, which may be flawed, is that this small diesel, maybe 2 cylinders would run at a constant rpm optimized for maximum fuel efficiency. This diesel would turn the generator, which would provide power to an electric motor or motors, to run the drive wheels. If a locomotive does this for torque, well, torque is a pretty good thing in a tractor. Plus, individual electric motors for each driven wheel would allow computerized traction control for less slippage (ideal for large acerage farming).
The principle of the small diesel is similar to the principle for APU's on large aircraft. Its a tiny jet turbine that provides power via generator for the aircraft when the main engines are off.
But, I suspect that in principle you are right and that if someone did the math, a diesel electric tractor might burn exactly the saem amount as a straight diesel. It just seems to me, that the diesel electric principle could be applied to one of these:
thumbnail.aspx
For the same reason it works in a locomotive. Presumably this is not the case or some smart fellow at John Deere would have already invented it. Oh well.
   / Countdown to Plug in Hybrid CUT? #26
Well...........according to Nasa scientists, in conjunction with scientist from Penn State University............Ya prolly ain't gotta worry bout that much longer:
Aliens may destroy humanity to protect other civilisations, say scientists | Science | The Guardian
I personally(after reading this article), would watch very carefully which scientist I rely on for information.
And as to mercury............buy a few more squiggly, curly-cue, light bulbs...........and dispose of them in lanfills:thumbsup::thumbsup::thumbsup:
Don - it's actually aliens from the planet Mercury that pose the greatest risk:
The Mercury Men - Main
Their plan is to use the steel framework of a high rise office building to enhance their gravity device which will pull down the Moon into the Earth!
   / Countdown to Plug in Hybrid CUT? #27
You are 45 miles from the nearest coal fired plant( CT only has 2)..............The chances of you smelling /seeing/tasting anything are lodged squarely at a minus 100!!!!!!! And there ain't no way it's affecting your corn............but if'n ya wanna get on a roll.............I'll tell you what to investigate.
Why do they not allow GMO foods across the big pond, and why has there been consecutive executive orders NOT allowing GMO crops to be evaluated by the FDA here in the good ole USA????
If you dig deep enough...........it will scare the crap out of you!!!!!
It would surely seem that way, but if you dig deep enough, reality has a cruel and perverse sense of humor. It turns out that theres a lot of coal generation upwind from us Nutmeggers and there is 100% chance that we suffer, directly, from the fallout:
New Report: Coal Power Plants Release Huge Quantities of Mercury, Polluting Streams and Rivers Nationwide - Jonathan Kantrowitz - Connecticut News
   / Countdown to Plug in Hybrid CUT? #28
Komatsu sells hybrid backhoe already. It recovers energy when the dipper goes down by gravity.
   / Countdown to Plug in Hybrid CUT? #29
Did you ever see an Electric push-back tug for an aircraft? It was huge for the massive batterys...Some companys have dropped them as they were maintence prohibitive, plus the batterys were larger than the big forklift items.The chargers were 3 phase 440 volt units...You pay more for Diesel fuel now because, the refinerys had to modify the process and add equipment to further remove the Sulfur from the crude. IE low sulfur fuel now sold.
   / Countdown to Plug in Hybrid CUT? #30
So thats ...........the rest of the story...........whoda thunk it :laughing::laughing:
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
2016 Deere 180G (A60462)
2016 Deere 180G...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56438)
PENDING SELLER...
