Correct hose sleve sizing for 1/2 JIC fittings
   / Correct hose sleve sizing for 1/2 JIC fittings #1
powerscol
SW Colorado
CT 235
Can someone please check my logic. I am going to be using 1/2 JIC fittings on some of my 1/2 in hose connection. Some of these will be the 1/2 in female ends that appear to measure 1" across the flat. It appears I will be putting them on after the hose are made. So I think I should get the 1.22" diameter product as I think the 1.05" diameter will be to tight to slide on, or does this stuff stretch a bit? Going to use the DHH nylon product, unless there is a better one.
There is a chance I can get this stuff put on when I get the hoses made but not sure. If I can should I got the the 1.05" for my 1/2 inch hoses? I don't think my Bobcat shop carries any sleeve material.
Thanks for the help
   / Correct hose sleve sizing for 1/2 JIC fittings #2
Which is larger, the distance across the corners of the hex or the crimp diameter? I would definitely get something that you are 110% sure will fit over the ends since you can easily tie the cover in place with wire ties.
You got me - thanks for the hint to re-measure across the corners. Something in the back of my mind said something was not right.
   / Correct hose sleve sizing for 1/2 JIC fittings #4
Just draw a Circle on paper of size sleeve, cut it out and see if it will go over fitting.
   / Correct hose sleve sizing for 1/2 JIC fittings #5
A hexagonal with 1" across the flats will be just a smidgen under 1.16 across the corners so you will need the 1.22" sleeves.
That's what I went with - arrived yesterday. Now on to " some assembly required" :D
Thanks Folks
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
DOOSAN DL250 LOADER (A51242)
DOOSAN DL250...
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
Club Car Carryall 500 Electric Utility Cart (A51691)
Club Car Carryall...
2011 Kia Sportage SUV (A51694)
2011 Kia Sportage...
