Correct hose sleve sizing for 1/2 JIC fittings
   / Correct hose sleve sizing for 1/2 JIC fittings #1
powerscol
SW Colorado
CT 235
Can someone please check my logic. I am going to be using 1/2 JIC fittings on some of my 1/2 in hose connection. Some of these will be the 1/2 in female ends that appear to measure 1" across the flat. It appears I will be putting them on after the hose are made. So I think I should get the 1.22" diameter product as I think the 1.05" diameter will be to tight to slide on, or does this stuff stretch a bit? Going to use the DHH nylon product, unless there is a better one.
There is a chance I can get this stuff put on when I get the hoses made but not sure. If I can should I got the the 1.05" for my 1/2 inch hoses? I don't think my Bobcat shop carries any sleeve material.
Thanks for the help
   / Correct hose sleve sizing for 1/2 JIC fittings #2
Which is larger, the distance across the corners of the hex or the crimp diameter? I would definitely get something that you are 110% sure will fit over the ends since you can easily tie the cover in place with wire ties.
You got me - thanks for the hint to re-measure across the corners. Something in the back of my mind said something was not right.
   / Correct hose sleve sizing for 1/2 JIC fittings #4
Just draw a Circle on paper of size sleeve, cut it out and see if it will go over fitting.
   / Correct hose sleve sizing for 1/2 JIC fittings #5
A hexagonal with 1" across the flats will be just a smidgen under 1.16 across the corners so you will need the 1.22" sleeves.
That's what I went with - arrived yesterday. Now on to " some assembly required" :D
Thanks Folks
TRUBILT SKID STEER QUICK ATTACH PALLET FORKS (A51244)
TRUBILT SKID STEER...
Year: 2008 Make: Chevrolet Model: Impala Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 (A51694)
Year: 2008 Make...
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
Wolverine Mini Skid Steer Auger Drive & Bit (A50515)
Wolverine Mini...
7616 (A47384)
7616 (A47384)
