Correct hose sleve sizing for 1/2 JIC fittings
   / Correct hose sleve sizing for 1/2 JIC fittings #1
powerscol
SW Colorado
CT 235
Can someone please check my logic. I am going to be using 1/2 JIC fittings on some of my 1/2 in hose connection. Some of these will be the 1/2 in female ends that appear to measure 1" across the flat. It appears I will be putting them on after the hose are made. So I think I should get the 1.22" diameter product as I think the 1.05" diameter will be to tight to slide on, or does this stuff stretch a bit? Going to use the DHH nylon product, unless there is a better one.
There is a chance I can get this stuff put on when I get the hoses made but not sure. If I can should I got the the 1.05" for my 1/2 inch hoses? I don't think my Bobcat shop carries any sleeve material.
Thanks for the help
   / Correct hose sleve sizing for 1/2 JIC fittings #2
Which is larger, the distance across the corners of the hex or the crimp diameter? I would definitely get something that you are 110% sure will fit over the ends since you can easily tie the cover in place with wire ties.
You got me - thanks for the hint to re-measure across the corners. Something in the back of my mind said something was not right.
   / Correct hose sleve sizing for 1/2 JIC fittings #4
Just draw a Circle on paper of size sleeve, cut it out and see if it will go over fitting.
   / Correct hose sleve sizing for 1/2 JIC fittings #5
A hexagonal with 1" across the flats will be just a smidgen under 1.16 across the corners so you will need the 1.22" sleeves.
That's what I went with - arrived yesterday. Now on to " some assembly required" :D
Thanks Folks
2014 John Deere 6125M Utility Tractor (A50657)
2014 John Deere...
2019 John Deere 8295R MFWD Tractor (A50657)
2019 John Deere...
1969 JOHNSON J25 GOOSENECK TRAILER (A51222)
1969 JOHNSON J25...
TEST BID LOT (A50775)
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
2023 Case IH 4412F 12 Row 30 In. Row Spacing Folding Corn Head (A50657)
2023 Case IH 4412F...
