rswyan
Super Star Member
- Joined
- May 12, 2004
- Messages
- 13,405
- Location
- Northeast Ohio
- Tractor
- Kubota B2910, Cub Cadet Pro Z 154S, Simplicity 18 CFC, Cub Cadet 782
Is a virus ever alive?
The following is from Irene Ken physician, whose daughter is an Asst. Prof in infectious diseases at Johns Hopkins University, quite informative.
* The virus is not a living organism, but a protein molecule (DNA) covered by a protective layer of lipid (fat), which, when absorbed by the cells of the ocular, nasal or buccal mucosa, changes their genetic code. (mutation) and convert them into aggressor and multiplier cells.
* Since the virus is not a living organism but a protein molecule, it is not killed, but decays on its own. The disintegration time depends on the temperature, humidity and type of material where it lies.
* The virus is very fragile; the only thing that protects it is a thin outer layer of fat. That is why any soap or detergent is the best remedy, because the foam CUTS the FAT (that is why you have to rub so much: for 20 seconds or more, to make a lot of foam).
By dissolving the fat layer, the protein molecule disperses and breaks down on its own.
* HEAT melts fat; this is why it is so good to use water above 77 degrees Fahrenheit for washing hands, clothes and everything. In addition, hot water makes more foam and that makes it even more useful.
* Alcohol or any mixture with alcohol over 65% DISSOLVES ANY FAT, especially the external lipid layer of the virus.
* Any mix with 1 part bleach and 5 parts water directly dissolves the protein, breaks it down from the inside.
* Oxygenated water helps long after soap, alcohol and chlorine, because peroxide dissolves the virus protein, but you have to use it pure and it hurts your skin.
* NO BACTERICIDE OR ANTIBIOTIC SERVES. The virus is not a living organism like bacteria; antibodies cannot kill what is not alive.
* NEVER shake used or unused clothing, sheets or cloth. While it is glued to a porous surface, it is very inert and disintegrates only
-between 3 hours (fabric and porous),
-4 hours (copper and wood)
-24 hours (cardboard),
- 42 hours (metal) and
-72 hours (plastic).
But if you shake it or use a feather duster, the virus molecules float in the air for up to 3 hours, and can lodge in your nose.
* The virus molecules remain very stable in external cold, or artificial as air conditioners in houses and cars.
They also need moisture to stay stable, and especially darkness. Therefore, dehumidified, dry, warm and bright environments will degrade it faster.
* UV LIGHT on any object that may contain it breaks down the virus protein. For example, to disinfect and reuse a mask is perfect. Be careful, it also breaks down collagen (which is protein) in the skin.
* The virus CANNOT go through healthy skin.
* Vinegar is NOT useful because it does not break down the protective layer of fat.
* NO SPIRITS, NOR VODKA, serve. The strongest vodka is 40% alcohol, and you need 65%.
* LISTERINE IF IT SERVES! It is 65% alcohol.
* The more confined the space, the more concentration of the virus there can be. The more open or naturally ventilated, the less.
* You have to wash your hands before and after touching mucosa, food, locks, knobs, switches, remote control, cell phone, watches, computers, desks, TV, etc. And when using the bathroom.
* You have to Moisturize dry hands from so much washing them, because the molecules can hide in the micro cracks. The thicker the moisturizer, the better.
* Also keep your NAILS SHORT so that the virus does not hide there.
-JOHNS HOPKINS HOSPITAL
Sounds like some of of you are finding all the bad news irritating. You need to turn it off and do something else like work on your tractor. :thumbsup:
Chris
Some of these states are 2 weeks late issuing stay at home. That痴 where the highest rates are. NY didn稚 shut down schools till last week, now FL let the beaches open and it痴 growing there.
Received this newsletter today. I don't live there but we do a fare amount of work in MD. Fire and rescue now infected.
COVID-19 Updates: County Executive Marc Elrich Stresses Social Distancing as County Cases Continue to Rise
Montgomery co is highest in the state. Someone came from a cruise with it, then went to a big gathering, and it multiplied from there. This was early on before the big alarm. 22 in my county next door.
Yeah, I was shocked to see MC that high myself. Maybe over in Baltimore or Anne Arundel I wouldn't be surprised. This time last year we had just finished a million dollar job in Frederick, I hope he makes it...
That isn't good.
That's pretty funny. Moss, you need to take a walk and get some fresh air!1 hour without a reply. Maybe the virus has peaked.
Well, while most of us are sheltering in place or just following the guidelines, we have these morons to contend with...Louisiana pastor defies coronavirus orders, holds church service for 1,8 people | Coronavirus | kctv5.com
Thank the idiots on spring break for spreading it.
Even worse are elected officials who continually denied anything needed to be done because they wanted to keep the economy rolling.<snip>
Lets not leave out those well-meaning church-goers, wedding celebrants, and Mardi Gras participants that couldn't stay apart. :worried:
Until the gov. steps in and tell you where to go or not go.The hospital in Murray KY (near Paducah KY) is expecting COVID-19 cases mid April 2020. The top floor (5th floor) is being converted to negative pressure next week. The lag in cases (2 currently at home) is enabling prep work. Hopefully this late push is enough. Reviewing the new numbers from east of the Mississippi River is mind boggling. One of my concern is the number of churches doing the parking lot Drive-In set up especially in the south to deep south. I am only one voice but I have total control over where I am going to be.
