Cooling Issue
/ Cooling Issue #32
That piston IS a mess. Whats the liner look like?
/ Cooling Issue #33
Somehow my reply to the OP has become truncated. So I will try to recreate it. The straight edges need to be long enough to span the engine block diagonally. The block must be checked lengthwise, crosswise, and diagonally. After the block has been scrupulously cleaned lay the straight edges on the block and use feeler gages to determine flatness. Just try to slip a feeler gage under the straight edge all along its length. Start with the .001" feeler and increase as needed. Put only enough pressure on the straight edge to insure it doesn't lift when trying to slip the feeler gages between the straight edge and the block. Before trying to determine flatness it is a very good idea to make sure there are no tiny high spots on the block. A tiny ding will raise material around the ding. You can use a FINE india stone with diesel or WD40 or a similar thin lubricant to check for high spots. Just slide the stone across the wet surface and if the stone hangs you have a high spot. Remove the high spot by running the stone across the high spot until the stone no longer hangs up. Use moderate pressure when doing so. If you don't have an india stone and can't find one easily then you can use a NEW fine cut file to remove high spots. It will tend to hang up just like a stone but will cut much faster. So use light pressure. Using a fine india stone and thin lubricant you can detect easily a high spot that is only .0001" above the surface being checked.
Eric
/ Cooling Issue
Why not clean the pistons up, new rings on them all, do a bit of fine emery cloth swirl to break the glaze on the sleeves and there all the same.
Thank you for your input. There is no glaze on any of the sleeves. I'm grateful for that. Two sets of rings seem fine. The middle piston got messed up. I would like to test compression on all three cylinders before putting the oil pan back on. Please give me any other advice you think of.
Is there a way to put a temperature gauge with a sensor near the middle piston? There was air in the cooling system and I think that through the temperature sensor off. I stopped the engine as soon as the idiot like came on. That was too late.
/ Cooling Issue
Eric
Thank you for the input. I need to get longer straight edges too span the diagonal.
What is that smallest feeler gauge that I need for this process?
/ Cooling Issue #37
Before you start bolting the rod ends to the crank, you should make sure that the journals are round and not flattened out.
/ Cooling Issue #38
Just buy a set of feeler gages. The thinnest will be .001". Start with that. But you will either need to find out online or here or from your machine shop how flat the block needs to be. I'm pretty sure it will be fine though. You still need to find out why the engine overheated. I suspect it ran out of coolant. So maybe you have a leak from a loose hose clamp or a split in a hose. I dunno if your engine has a water pump. If it does they can go bad. If not, if your engine is a thermosyphon, then maybe you had the wrong coolant mixture. But you gotta figure it out.
Eric
/ Cooling Issue #39
Those tractors, I believe, were Yanmar engines. On a lot of those they used crank pulleys that were "Clutches", meaning they had friction material when engaged. The material wears out over time, so your cooling fan doesn't spin as fast as it should to move air through the radiator. Something to check and keep an eye on, but what I see in your video, I feel you have exhaust gasses going into your coolant from a blown head gasket. You can buy a tester, easy to use, to verify.
/ Cooling Issue #40
Eric
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
INGERSOLL RAND G25 GENERATOR (A58214)
INGERSOLL RAND G25...
2023 Kubota L6060HST Compact Utility Tractor (A61307)
2023 Kubota...
2008 Godwin Dri-Prime CD103M Towable Trash Pump (A59228)
2008 Godwin...
2016 FREIGHTLINER CASCADIA (A60736)
2016 FREIGHTLINER...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
