JD X749 Dying after 30-45 minutes
   / JD X749 Dying after 30-45 minutes #163
Thanks Andy, I appreciate it.
Hope it helps. When I first had my X748 I ran it out of fuel.. Needed dealer assistance to get it restarted. Only failure I've had in 10 years was a bad fuel solenoid
   / JD X749 Dying after 30-45 minutes #164
darn, It made so much sense with it being the relay cutting out the hold in voltage only temporarily. Maybe take a solid look at the fuse block that relay is attached to. It may be cracked.
Can you figure out a way to run it with the fuel stop solenoid removed from the machine. Just thinking out loud but is there a spring in the injection pump that returns that fuel stop plunger to the run position.
Yea, we discussed that earlier by plugging the hole (oil will leak out) and inserting a probe to turn the engine off. I was thinking of just rewiring it directly without going through the system, but if there is a problem in the injector pump the problem will still exist.
I called JD today to find if there is a diagnostic port. They said no, but that there is a way they turn the ignition off & on 3 times and check for a blinking light to give a code. I asked if I can come in and try it, but there is a 2 week backlog with no appointments, first come first serve. How's that for running a business?
2012 JOHN DEERE 160G LC EXCAVATOR (A52705)
2012 JOHN DEERE...
GODWIN CD150 DRI PRIME PORTABLE PUMP (A51406)
GODWIN CD150 DRI...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
