coolant
/ coolant #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I'm over 2 years and need to change the anti-freeze. Should I flush or just drain/refill? Use distilled water or just get a pre-mix? What's the best antifreeze to get?
/ coolant #2
I simply flush mine with tap water, close it up and run till normal operating temp, drain and fill with (Fleet Guard) brand anti-freeze from TSC, mixed 50/50 with distilled water. The small amount of coolant required is inexpensive and over-kill IMO, but it keeps me happy
/ coolant #3
Just drain and refill. Mixed 50/50 with clean tap water. Just like you do on anything else. I don't know if any brand is better than the other.
/ coolant #4
I drain than run water thru 10mins or so than drain follow by 50/50...no problems.
/ coolant #5
I drained and put in a cleaner. It wasn't much $$ and the tractor is a significant investment. After 15 minutes of idle, I drained that to dispose of with the green conventional coolant and added pink extended life with a 50/50 mix of distilled water.
/ coolant #6
I drain, refill with plain water, run the tractor for 10-15 minutes and drain. Refill with concentrate that I mix 50/50 myself. I use 5 year extended life antifreeze.
/ coolant #7
I have a gal of 5o/5o DexCool "permanent" that I'd like to use in my CK30 and get rid of the green stuff. Any reason not to use it?
/ coolant #8
What brand of 5 year did u use?
John Deere 7000 4R Wide Planter (A66285)
John Deere 7000 4R...
8ft. x 4ft. Lighted Sign (A65640)
8ft. x 4ft...
CHANDLER 10' STAINLESS STEEL FERTILIZER SPREADER (A64277)
CHANDLER 10'...
John Deere Fork Attachment (A62613)
John Deere Fork...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
