coolant
/ coolant #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I'm over 2 years and need to change the anti-freeze. Should I flush or just drain/refill? Use distilled water or just get a pre-mix? What's the best antifreeze to get?
/ coolant #2
I simply flush mine with tap water, close it up and run till normal operating temp, drain and fill with (Fleet Guard) brand anti-freeze from TSC, mixed 50/50 with distilled water. The small amount of coolant required is inexpensive and over-kill IMO, but it keeps me happy
/ coolant #3
Just drain and refill. Mixed 50/50 with clean tap water. Just like you do on anything else. I don't know if any brand is better than the other.
/ coolant #4
I drain than run water thru 10mins or so than drain follow by 50/50...no problems.
/ coolant #5
I drained and put in a cleaner. It wasn't much $$ and the tractor is a significant investment. After 15 minutes of idle, I drained that to dispose of with the green conventional coolant and added pink extended life with a 50/50 mix of distilled water.
/ coolant #6
I drain, refill with plain water, run the tractor for 10-15 minutes and drain. Refill with concentrate that I mix 50/50 myself. I use 5 year extended life antifreeze.
/ coolant #7
I have a gal of 5o/5o DexCool "permanent" that I'd like to use in my CK30 and get rid of the green stuff. Any reason not to use it?
/ coolant #8
What brand of 5 year did u use?
2010 CATERPILLAR 120M AWD MOTORGRADER (A63276)
2010 CATERPILLAR...
Allis Chalmers WD-17 Rim (A65640)
Allis Chalmers...
2017 Ford Explorer 4x4 (A62679)
2017 Ford Explorer...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
2014 Chevrolet Tahoe SUV (A64194)
2014 Chevrolet...
(4) Rims (A65640)
(4) Rims (A65640)
