coolant type
/ coolant type #1
psuedofarmer
new hampshire
Kioti DK55 Cab, 3 NHs (from 40-90HP)
can anyone shed light on the coolant type i should use for my DK55? the manual does not specify..
pf
/ coolant type #2
The regular old green stuff used in autos will work just fine. Nothing special about it.
/ coolant type
thanks jon.. that's exactly what i expected (kind of like 'who wants to be a milliionaire'.. i KNEW that!).
cheers.
pf
/ coolant type #4
Sorry John but I have to disagree with your reply to the automotive anti-freeze being used in a diesel engine. The corrosion inhibitors in antifreeze used for automotive applications are different than those used in heavy duty diesel engines. Electrolosis and/or cavitation (pitting) of the cylinder sleeves can and does occur in diesel engines. In fact I have actually seen cylinder sleeves pitted clear through from the anti-freeze side-not the piston side. Usually this is due to the additives breaking down after a short while and the pitting can be quite severe in suprisingly short amount of time. I have also seen diesel engines with the sleeves so rusted in that it is nearly impossible to remove them. All due to the wrong antifreeze. My thought is if you are going to skimp on something don't do it on something that is going to be in your engine for an extended period of time. It's not woth the few buck you save initially. Get a heavy duty anti-freeze labeled for diesel engines. Look for borate/nitrite inhibitors in your antifreeze to prevent electrolosis/cavitation in wet sleeves.
/ coolant type #5
That is what they are supplied with from the factory. These engines don't have a sleeved cylinder engines.
/ coolant type #6
Jon, just to satisfy my curiosity, are there no sleeves or are they press fit sleeves? And is this consistent with all of the Kioti tractors or this particualr model? Excluding the Dk 65 which I understand is a perkins engine and probably is a sleeved engine.
/ coolant type #7
They use to have sleeves back in the past onthe 20HP - 30HP . All the newer (I wanna say around 95 or so) have no sleeves. Main reason behind this is it just wasn't cost effective for a customer to rebuild an engine vs. buy a complete engine from Kioti. And you get more with the new engine vs rebuild.
2016 CHEVROLET CAPRICE CAR (A66091)
2016 CHEVROLET...
1947 Chevrolet Panel (A62613)
1947 Chevrolet...
2018 Ford Explorer AWD SUV. (A66738)
2018 Ford Explorer...
2013 HILL COUNTRY (A67714)
2013 HILL COUNTRY...
80015CFL (A64556)
80015CFL (A64556)
2008 FORD F250 CREW CAB PICKUP TRUCK (A66091)
2008 FORD F250...
