Coolant flush procedure issue
/ Coolant flush procedure issue #21
had a similar issue with my New Holland.... it was dirt caked on the radiator fins, that got by the screen.
/ Coolant flush procedure issue #22
I use a radiator pressure tester to check for air in system when it’s been drained & refilled.
If you have air in system it will take many pumps to build pressure. If there is no air in system the pressure will build within two or 3 pumps.
If there is air in system pressurize it to 10~15 psi then release pressure a couple times to move trapped air. You can then start engine and pressurize it and release pressure a couple times to help.
90cummins
/ Coolant flush procedure issue #23
I also prefer refractometers for coolant concentration measurements. They are not that expensive, and much more reliable and accurate.
I have never made a coolant concentration measurement for flush and refill situations. You already know the concentration is 50%. And if adding coolant I stick with the 50-50 mix.
Harlo HP6500 (A60462)
1988 Ford 8210 (A60462)
1988 Ford 8210...
2024 ANKONA 54" HANG-ON WHEEL LOADER FORKS (A62129)
2024 ANKONA 54"...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
(INOP) MASSEY FERGUSON 263 TRACTOR (A59823)
(INOP) MASSEY...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
