Cool down timer
/ Cool down timer #1
Walter L
Delhi LA
LS XG3135, Foton FT404,Farmtrac 555 ,Kubota L245H offset garden tractor Mahindra 2660 cab tractor
Well guys i have been bitching about having to set on my tractor with it idling from 3 to 5 min to cool the turbo down after using it hard. My son got tird of hearing me complaining and built me a timer.
Bought The timer from Documentation , this is a programable timer and good for 5A and that is all that was need on my XG3135 tractor, i used a relay and taped the timer to the relay when i installed. You can use a button switch or a spring loaded rocker switch to activate the timer. I have tested the timer and found out that any safety switch like the seat switch will cancel the timer, how i got past this is i get off the tractor go around the tractor to the ignition switch side mash the rocker switch then turn off the ignition key and timer will run the engine for the time you program in the timer.
On the timer i did not used the blue, white and green. On the relay i did not-use the orange.
Forgot to mention that i used a 5A fuse where i came off the ignition switch for power.
I see the link i posted does not work just do a search for the Timer shop on Amazon
/ Cool down timer #2
Why do you have to stay in the seat and wait? Seems that you could put it in neutral, set parking brake or whatever and leave the seat. If you can't, I would disable the operator presence switch. Just a minute while I put on my fire retardant suit!
/ Cool down timer #3
The big trucks have them you can turn the key off lock the doors and walk away and it will shut off in 5 minutes or push the button to shut it right off .. Nice job on the install...........:)
/ Cool down timer
Why do you have to stay in the seat and wait? Seems that you could put it in neutral, set parking brake or whatever and leave the seat. If you can't, I would disable the operator presence switch. Just a minute while I put on my fire retardant suit![/QUOTE
Well without a timer shut off system you dont have a choice, you could let it idle while you do your other chores but then i would forget it and then 1 hr later i might remember so the timer takes care of that it will idle it at a predetermined time to cool the turbo down, why do i need to cool the turbo down after hard use do you know?
The fire retardant suit what what is that about or do you just post crap to try and piss folks off instead of posting something constructive ?
/ Cool down timer #5
Must be something new.
I've never been around a truck with that setup.
/ Cool down timer #6
He was not trying to annoy you or anyone. He was acknowledging that his post violates a safety procedure, which a lot of folks on this forum take issue with. Safety items are there for a reason, and it was a round about way of letting everyone know that he is aware his recommendation bypasses safety items that were installed by the manufacturer.
/ Cool down timer #7
No my buddy's 1987 peterbilt had one new from factory...
/ Cool down timer #8
3T's hit the nail right square on the head and drove it home with one whack!
Not trying to piss you off Walt.
/ Cool down timer
Thank you for clearing that up! And I apologize for getting my shorts in a wad.
/ Cool down timer
Then we have more in common Than I realize , i feel the same way.
VERSATECH 66" GRAPPLE RAKE (A64277)
VERSATECH 66"...
2017 Ford F-150 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
2022 EZ-GO ELITE...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64277)
KNOW BEFORE YOU...
New Landhonor 78" Rock Bucket  (A62679)
New Landhonor 78"...
Landhonor Quick Attach Power Rake (A66408)
Landhonor Quick...
