Converting Pneumatics to Hydraulics
/ Converting Pneumatics to Hydraulics #1
TexasSD
Parker County, Texas
Zennoh ~ L225
A buddy of mine is cleaning out a warehouse full of obsolete cabinet making equipment. In addition to a lot of steel that I am going to scavenge, the equipment has a bunch of pneumatic cylinders that he said I could have.
Some of my projects are going to require hydraulic cylinders, so in the spirit of recycling (and generally being cheap), I was wondering if these cylinders could be used as is or modified for hydraulic use.
Thanks for the help!
Scott
/ Converting Pneumatics to Hydraulics #2
the problem with the pneumatics is they arnt in the same force range as hydrolics.
avg hydrolic pressures are 1-2K psi.... avg pneumatic line pressure is 100-150PSI... or an order of magiatude less.
so what might be a 4000lb hyrolic ram is now a 400lb pn3eumatic ram... ie not good for much in the tractor world...
I thought the pressures would be the major issues, but was unsure how the differences in fluid dynamics between air and oil would affect the ram's performance.
Thanks for your reply!
/ Converting Pneumatics to Hydraulics #4
The fluid dynamics are the same, PSI applied to the surface area of the piston determines ram force. Unfortunatly, if you plumb them into a typical hydraulic system, they will burst as you will be exceeding their pressure rateing by nearly 10X:).
(INOP) 2018 FORD EXPLORER (A59823)
(INOP) 2018 FORD...
8ft. x 4ft. Large Man Basket (A65640)
8ft. x 4ft. Large...
2010 Chevrolet Tahoe SUV (A64194)
2010 Chevrolet...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2018 Bobcat E35i Mini Excavator (A61572)
2018 Bobcat E35i...
BUSH HOG 1815 - 15' BATWING ROTARY MOWER (A64277)
BUSH HOG 1815 -...
