Converting old thermostart to electric
   / Converting old thermostart to electric #12
FWIW: Here is a Thermostart diagnosis, disassembly, and replacement. (On a slightly larger machine...)
All the best, Peter
   / Converting old thermostart to electric #13
All the best, Peter
FWIW the Thermostart portion of the video starts at the 4 minute point.
Slide-on vs screw electric connector is the only difference between versions and most will take either. They are cheap to replace. I see several under $15 on Ebay.
   / Converting old thermostart to electric #14
About $9 on Amazon if ordering the Ford 1000 Series tractor types. It's the same product. We pay a tad bit more for the Yanmar name, even in the aftermarket circles. I've already replaced mine last year with the Ford identical version.
   / Converting old thermostart to electric #15
Great! Amazon is the best source then.
Before posting I searched Amazon on 'Thermostart' and nothing at all was found. So I went to Ebay.
It was/is also used on the Perkins diesels in MF, and many other tractors and industrial engines. The device is a Perkins patent.
What does Ford call it?
Photo after I bought a new one at the local ThermoKing (reefer on semitrailer) dealer.
dscn5123thermostart-perkinsbox-jpg.68476
   / Converting old thermostart to electric #16
Ford calls it a Thermo-start air-intake heater or manifold heater.
I bought mine thru AI products (aka John Deere owned aftermarket co.) here:
It's listed on Amazon for $15 thru others now.
   / Converting old thermostart to electric #18
The hard parts to find are the tubing lines and little reservoirs.
   / Converting old thermostart to electric #19
Thermostart works fine if it works properly. My old big tractor was a beast to start. So I got two freeze plug heaters, a lower radiator hose heater, covered the hood with a blanket. Plug it up and it was hot in 30 minutes. I like cranking a warm engine, easier on the engine. Most wear happens on cold starts. I had thermostart too, but it was easy when warm, busted right off.
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
2019 Chevrolet Tahoe (A56859)
2019 Chevrolet...
2016 Ford Explorer AWD SUV (A56859)
2016 Ford Explorer...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
2016 Chevrolet Cruze Limited Sedan (A56859)
2016 Chevrolet...
Kubota L4701 (A53317)
