Converting Hydraulic PTO driven implement to PTO
/ Converting Hydraulic PTO driven implement to PTO #1
pekabu
Platinum Member
NH
TC24D
I just purchased a snowblower that was driven by a hydraulic motor. The motor is no longer there. I would like to convert it to PTO use. It turns the right way. It is setup to take a 1" shaft with a key.
So, any suggestions on how I should do this?
/ Converting Hydraulic PTO driven implement to PTO #2
Did the hydraulic motor run the snowblower at 540 rpm? If it was much higher or lower, you could have a problem much greater than just hooking up the PTO. Have you checked with the manufacturer to see if they make a PTO direct driven model? If so, they might have all the parts you need. /forums/images/graemlins/cool.gif
Thanks, I am working that angle now. I don't believe they made a 3pt model.
/ Converting Hydraulic PTO driven implement to PTO #4
Find the rpm it was designed to run, then go from there. If that is is.. just get a pto shaft with the appropriate yoke.. shouldn't be too hard to find.
If it isn't the right speed.. you may be looking for a hyd motor and running it off a remote.. or off a pto powerd pump.. etc.
Soundguy
/ Converting Hydraulic PTO driven implement to PTO #5
If you have the aux hydraulics, the motor would probably be cheaper than the shaft and u-joints. Probably 50 of them on ebay right now 9.95 to 49.95. Hyd Surplus is another good spot too.
2015 JLG G12-55A 12,000lb 4x4 Rough Terrain Telehandler (A61572)
2015 JLG G12-55A...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A64279)
2008 CATERPILLAR...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2023 New Holland C327 Compact Track Loader Skid Steer (A61572)
2023 New Holland...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2005 Ford F-350 Stakebody Flatbed Truck w/ Liftgate (A61573)
2005 Ford F-350...
