Converting double acting cylinder with a single acting pump
   / Converting double acting cylinder with a single acting pump #1
rfc143
Vermont
kubota 5240
Have a dump truck with a double acting cylinder. Replacing the pump with a new single acting pump.
There’s no place to attach the rod end hose.
Can I just take the hose off and leave it open to atmosphere?
   / Converting double acting cylinder with a single acting pump #2
Get a breather for that port and run it that way.
That's how I did on my homemade dump trailer. Just used a double acting cylinder and used a breather on the rod end port.
Hard to see on the picture but that's the thing sticking out on the rod end port.
EDIT: Surplus Center has those: Caps & Breathers | Hydraulic Filters | Hydraulics | www.surpluscenter.com
   / Converting double acting cylinder with a single acting pump #3
If.....
The cylinder piston packing ever starts passing fluid, a line back to TANK would be less messy than a breather.
But more complication......
There are two holes on the top of the tank; both threaded. I’ll run the system for a while as I’d like to see if the piston is leaking,then plumb the hose to one of the holes. The other one is a breather, so there’s no danger of pressurizing the tank.
   / Converting double acting cylinder with a single acting pump #6
Messy can be your freind. If you have a leaking cylinder you want to know sooner than later. If you’re plumbed back to the tank, so there isn’t a mess, then you won’t know anything is wrong, until you have a serious failure.
Similar to why you don’t caulk around a toilet base. You want to know the wax ring isn’t seated and fix it, before the leak rots out the floor.
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
2016 CATERPILLAR 259D SKID STEER (A60429)
2016 CATERPILLAR...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
