Convert Joystick
   / Convert Joystick #1
relhogh
Florida
Yanmar 1500d
I have a Yanmar 1500d and would like to convert my joystick to have a free float position.
It is a VTEKS HD V1A loader.
Is it possible?
Could I afford to do it?
Thanks for any suggestions. Even funny ones
   / Convert Joystick #2
Loader valves usually have float.
   / Convert Joystick
Thanks JJ
But being a novice to the tractor world is there a easy way to find out.
Like what to look for.
I can't find anything about the loader itself.
Is there a way to tell by looking a the valve?
Thanks
   / Convert Joystick #4
With the tractor running, pull the joy stick lever fully back to raise the loader, Then push the stick fully, fwd, and it should lock in fwd and if it has float, the lift arms should descend to the ground and the lever will stay in float until you pull it back to neutral.
Another way, is to tilt the bucket down and then push the lift arms lever fwd until the wheels are off the ground, and then push lever fully fwd and the tractor should descend to the ground. The lever should detent in float.
If the wheels stay in the air, you either do not have float or the float is not working.
If you need a loader valve, here is one that will work.
http://www.surpluscenter.com/item.asp?item=9-7401&catname=hydraulic
This valve has float and regen.
Regen is used to make the bucket dump faster.
   / Convert Joystick
Thanks again J J
I will try your suggestions as soon as the rain and wind stops.
Besides its nap time.
   / Convert Joystick
Tried your suggestions and it looks like a $200 plus fix.
Needs some deep thought.
Thanks again J J
   / Convert Joystick #7
I would just add, the trick to what JJ is saying is when you push the stick forward looking for float, you will have to push it harder than usual to over come some resistance of the detente ball or what ever it is.
Many have said it took several attempts to find float even though they knew their machine was equipped with it, just because at first it is somewhat of an unnatural movement/motion.
JB.
   / Convert Joystick
Thanks 4310
I will give it another go.
   / Convert Joystick #9
Let me know if this is the way you work your loader.
Push stick fwd, lift arms go down, push fwd past the detent, loader arms go into float. Pull the stick back and the lift arms go up. Push the stick to the left, and the bucket curls up, and push to the right, bucket tilts down.
Some FEL valves also have regen, and that occurs when you push the stick to the right past the detent, you will have fast dump.
Look at page in the PDF below for joystick description.
http://www.surpluscenter.com/Instruct/I9-7401.pdf
   / Convert Joystick #10
Wow! you may of just answered a mystery I had.
My loader valve has the regen option and I tried but didn't notice anything different, didn't know there was a detente there to go past :confused2:
I'll have to try it again, can't really think of a need for such quick dumping, maybe snow removal. But I sure would want to know how it works, especially since I thought I knew it all :ashamed:
JB
2018 MDB T5E MDB DISC MOWER (A51247)
2018 MDB T5E MDB...
PALLET OF SCAFFOLDING (APPROX. 12 PC) (A52706)
PALLET OF...
New Holland TS6.130 4WD Utility Tractor with Rotary Mower (A53421)
New Holland...
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
1981 AZTEC SKINNY NECK 31 FOOT FLATBED (A53843)
1981 AZTEC SKINNY...
2018 CASE IH 110N LOT NUMBER 207 (A53084)
2018 CASE IH 110N...
